Old 02-02-2005, 01:06 AM
jhmcrx's Avatar
jhmcrx jhmcrx is offline
Crx Ground Wiring
since i will be carless for a little while i might as well make some new ground wires, but i need to know all the grounding point on my crx.
Thanks in advance for your help
1988 CRX DX
MODS:
Garrett T28 turbo
450cc DSM injectors
TurboEdit
STD manifold W/adaptor plate
dsm bov
stealthemodeperformance.com oil line's
Tsudo cat back
basic hi flow cat
front tower bar, rear tie bar
short throw shifter
and other small stuff
Old 02-02-2005, 01:22 AM
Hybrid1990crx's Avatar
Re: Crx Ground Wiring
to your frame, rad support, clutch lever, battery, thermostat...
Old 02-02-2005, 01:25 AM
jhmcrx's Avatar
where on th radi support?
sry 4 stupid question, im lazy and tired
1988 CRX DX
MODS:
Garrett T28 turbo
450cc DSM injectors
TurboEdit
dsm bov
Tsudo cat back
basic hi flow cat
short throw shifter
Old 02-02-2005, 01:35 AM
usually next to the driver side headlight
Old 02-02-2005, 02:14 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
its on the valve cover
Team Lonely Drivers
Old 02-02-2005, 02:51 AM
yeah valve cover to rad support.
Old 02-02-2005, 07:33 AM
midrange midrange is offline
Send a message via MSN to midrange
and your main ground from battery to transmission bolt. thats the important one! A ground is a ground, whether you ground it to the its original factory grounds or anywhere else on the body.
Old 02-02-2005, 11:29 AM
Re: Re: Crx Ground Wiring
Battery ground goes to the frame first and then to the trans. DUHHHHhhhhHHH. lol.
And a ground is not a ground. Bigger guage wires = better grounds.
