Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 02-01-2005, 11:09 PM
blktaho blktaho is offline
fender flare removal
hi guys maybe im an idiot here, but i was wondering how to get off those plastic oem fender flares, also if it was bonded to the paint in anyway.
Old 02-02-2005, 03:50 PM
yukongt9682 yukongt9682 is offline
I've do this too many times to count in an escalade conversion and repainting my truck. Unless the truck has been repainted without taking the flares off as they should have been you shouldn't have a problem. If so there is more than likely paint along the seam and could cause chipping when you try to pull them off. For the rear there are four nuts you can get to from the fender well area and two inside the truck that require you to remove the back interior panels, a real pain. For the front I never found a better way to get them off other than taking the entire fender off. Again there are 6 nuts or so holding it on probably four you can reach from the motor compartment (but your gonna have to move some things), but the bottom two at the bottom of the fender are impossible to get too with the fender on the truck. So taking it off is the easiest way in my opinion. If you do get the front off with it on the truck putting them back on is another story, try getting this little nut on where you can't reach without dropping it, and when you do drop it they fall futher down in the fender, a real pain in the a**. Hope this helps.
brad
Old 02-02-2005, 06:02 PM
Re: fender flare removal
thanks thats really what i was looking for, the other question i had was whether they are adhered with any glue or anything, especially because i have part of the flare attached to my rear, door.
Old 02-02-2005, 06:04 PM
also i was wondering if they were drilled into the actual panel so that i would have to repaint my truck.
Old 04-01-2005, 11:09 PM
blacktahoe4x4 blacktahoe4x4 is offline
Send a message via AIM to blacktahoe4x4
they should have double stick tape on the outside and screw or fasteners in the fender well u shouldn't have to repaint
3in body 2in torsion keys 1in spring spacer 17x8 american racing mohave teflon 305 wrangler mtrs billet grill projest head lights clear corners 2 kicker 15's superchips programer k&n gen 2
CCI OFF ROAD
