Old 02-01-2005, 10:29 PM
2CrX's Avatar
2CrX 2CrX is offline
Pics of the motor
I posted a few weeks ago about my buddys b20 vtec that blew up. Well he finally got the pics developed. There not great but here are a few.
The center of the piston is gone but the cylinder walls where not very bad.
As I posted before, all 4 valve heads where gone. But the stems where still in place. Its kind of hard to see in the pic, but the entire combustion chamber in the head looked exactly like the top of the piston. Except for the hole. Any ideas on what happend?
Old 02-01-2005, 10:46 PM
Hilikus Funkin's Avatar
Hilikus Funkin Hilikus Funkin is offline
Send a message via AIM to Hilikus Funkin
Re: Pics of the motor
wasnt built right is my guess. same thing as ls/vtec you gotta do a bunch of shit with fittings and all.
1991 Honda Civic DX Sedan
Old 02-01-2005, 10:53 PM
2CrX's Avatar
all the fittings where fine, it ran with the stock bottom end for a long time. then he put high compression pistons(11.5 to 1 i think) in it. And it ran good and strong for a while after that.
Old 02-02-2005, 01:21 AM
88CiViC_D-15's Avatar
88CiViC_D-15 88CiViC_D-15 is offline
Send a message via AIM to 88CiViC_D-15 Send a message via MSN to 88CiViC_D-15
looks like a melt down, but why only on 1 cylender, maybe there was something in the cylender and it caused this all to happen. but i dont know
Team Lonely Drivers IS LOOKING FOR MORE MEMBERS,CLICK HERE
TLD FOURMS
- 88 civic std w/ sohc zc swap
- 88 integra ls, stock
- lookin for a 4dr. runnin or not
Old 02-02-2005, 09:48 PM
See See is offline
We blew up a race motor out of a GSXR 1100 that looked just like that.We determined the cause was one of the cam gears slipped at 11,500 rpm.
Old 02-02-2005, 09:50 PM
jhmcrx's Avatar
jhmcrx jhmcrx is offline
....ok
1988 CRX DX
MODS:
Garrett T28 turbo
450cc DSM injectors
TurboEdit
STD manifold W/adaptor plate
dsm bov
stealthemodeperformance.com oil line's
Tsudo cat back
basic hi flow cat
front tower bar, rear tie bar
short throw shifter
and other small stuff
Old 02-02-2005, 09:59 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
if i had to guess, id say that the injector failed and it ran lean. the combustion temp would be a lot higher, and that could cause the valve stems to get hot and melt. this is just a guess though.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 02-02-2005, 10:15 PM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
detonation? weird that it ran well for a while and then that one cylinder gave out. Maybe when he last modded his engine he damaged it without knowing? How long was he running the engine?
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
Old 02-02-2005, 11:57 PM
kpeters0929 kpeters0929 is offline
This is a pic of when i blew my b16 up..overrevved it. Pretty nasty.
Old 02-03-2005, 12:32 AM
2CrX's Avatar
Damn kpeters, That sux.
He was running it for about 4-5 months when it blew. He said that he was driving normal at about 5k when it happend. Just died. It was put together by a shop in Florida.
