Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 02-01-2005, 10:25 PM
HotCrew's Avatar
HotCrew HotCrew is offline
Send a message via AIM to HotCrew
T25 Wastegate
I was wondering what harm there would be in moving the stock wastegate from its mounted positioned? I am doing a custom turbo setup and the wastegate rod makes contact with the starter. Can i move the wastegate up or down without damaging the operation of it? Or should I go ahead and re-weld my manifold?
Check out my site
After Night Groove Team Site
RS-T Build Up Site
http://www.angelfire.com/pro2/rst
Old 02-05-2005, 02:06 PM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
Re: T25 Wastegate
I personally do not see what it would be detrimental to move it. But I have not done any research or anything on it, so don't do it just because of what I said...to me it just seems like it should be okay.
"You can have everything in life you want if you will just help enough other people get what they want."
Old 02-05-2005, 04:23 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: T25 Wastegate
just make sure that the wastegate opens and closes completly and you should be fine. i dont think there would be much room to move but you can try
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 02-05-2005, 05:00 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: T25 Wastegate
Hey man, I forgot about what car you had when we were talking the other night. I personally would not go with an internal wastegate if I were you... The one on a T-25 is set at 11-12psi and you definately dont want to be running that high unless your motor is built! Just a thought!!
Old 02-06-2005, 02:02 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: T25 Wastegate
Actually I believe the t25 is more like 7-8 psi. The mitsu actuators are ~10 psi. But it may creep more than 7-8 psi anyway, making the spring pressure irrelevant.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 02-06-2005, 09:23 AM
HotCrew's Avatar
Re: T25 Wastegate
Thanks for the feedback guys! A boost controller will control the psi right? I think i am going to move it up and make a mounting bracket for it. I will just have to monitor it and make sure that there isnt a leak.
Check out my site
RS-T Build Up Site
Old 02-06-2005, 12:56 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: T25 Wastegate
Yes, a boost controller can increase boost... but it will not lower it below the wastegate's preset. You will not be able to run lower than ~9psi with a boost controller or not. I would go with an external wastegate, but I have never heard of anyone considering adjusting the wastegate position. Seems like you could make the rod longer or shorter.
