Old 02-01-2005, 10:16 PM
fussman238 fussman238 is offline
Send a message via AIM to fussman238
Clutch Blood
Ok today I was putting in some new speakers when I noticed a oily spot surrounding my clutch pedal i touched it and it was really wet. Im thinking its the master cylinder but i want a second opinion. Funny I just got the slave replaced 3 weeks ago..
Old 02-02-2005, 08:20 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: Clutch Blood
sounds like your master cylinder leaks. how does the clutch pedal feel when you drive? keep an eye on the fluid level until you replace it
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 02-03-2005, 05:28 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Clutch Blood
It would help if we knew wtf kind of car you have
The 2g master is at the other end of the rod that is attached to the pedal. The 1g master is to the right of the gas pedal, its operated by a POS linkage system that runs behind the pedals.
In either case, if the leak is at this rod that goes to the master, then that is the problem.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
