Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 02-01-2005, 09:09 PM
bcopeland bcopeland is offline
1986 Fiero won't start
We are trying to start an 86 Fiero. We replaced the ignition coil because it was not getting fire. We have a new fuel injector in there - at least it was new when we put it in several years ago. We have not run it regularly since then. Now, it acts like it wants to start, but won't. Poured gas down the throttle and it will act like it wants to start for about 1 - 2 seconds. Any thoughts?
Old 02-05-2005, 05:48 PM
Damarr30's Avatar
Damarr30 Damarr30 is offline
Send a message via Yahoo to Damarr30
Re: 1986 Fiero won't start
Bad fuel pump?? That was my problem.
Old 02-06-2005, 02:45 PM
poncho1978 poncho1978 is offline
Can you see fuel being sprayed into the throttle body while cranking it over? Is is a 4 or 6? If there's no spray in the throttle body, unhook the gas line at the fuel filter and have someone crank it. If you have no gas, its probably the pump, which is in the tank. Not a real hard job, but can be messy. Hope that helps. Let me know how it turns out.
Patrick
Old 04-26-2005, 03:33 PM
Its a 4 and I believe after we did what you said, we did see gas at the filter. I did not remember seeing it come out of the injector.
