obd0 pr3 ecu throwin a code 9?
what is the code 9 for the Pr3 ecu? and how do i fix it, any help would be great thanks
Re: obd0 pr3 ecu throwin a code 9?
for future reference:
http://tech.hybridgarage.com/tech/codes.html 9* CYP Sensor (Cylinder) defective circuit or unplugged / defective sensor
"hi! my name is Lady, and i'm a HONDA-holic" ..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose! ![]() *~ I <3 the G Ride ~*~ I <3 OLD SKooL |
where is the cyp sensor located? thanks
its in the distributor. did this just come up recently, or has it been there since the swap?
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud. |
it just recently came up..........
take your cap off, and see if theres any metal shavings in it. the sensor seldom breaks, but sometimes the distributor shaft bushings wear out and the pieces damage the sensor, or just make the shaft wobble and throw a code.
if it is the sensor how do i replace that?
you cant. its pressed on to the shaft. you need to change the distributor
k thanks for the help but i will check out for those shavings u were talkin about
