Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 02-01-2005, 08:04 PM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
B16A3 swap
Before i start, i just want to state that i have tried to search the forums, but the search must be down. It keeps telling me that my search is under the minimum word length when it isn't. MY situation is this. I have a wrecked 94 del sol VTEC model with a B16A3 in it. I want to take this engine out of the sol and put it in a 88-91 CRX SI. I know where to get the OBD0 to OBD1 wire harness, but what else will i run into that i need to be aware of. If there is any websites with a walkthrough, it would really help. I know i will need engine mounts too, but i am really worried about the wiring. I want a clean install with no check engine lights or any problems; Like the motor was supposed to be in there. Thanks for any help in advance. Oh yeah, i keep hearing stuff about dizzy's; whar are they. I'm sure i know, i just don't know the term.
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
Old 02-02-2005, 12:22 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: B16A3 swap
dizzy is distributor, know what that is ?
well since you have a complete motor, take the engine harness from the delsol and splice in the injector clips and the dist plug. so basically your making the plugs fit obd1. you will also need the o2 sensor and since you have it, it will be all plug and play
Team Lonely Drivers
Old 02-02-2005, 06:08 AM
Re: B16A3 swap
of course i know what a distributor is . i just didn't know the slang. Any walkthroughs that anyone knows of?
