Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 02-01-2005, 07:06 PM
samjaynes samjaynes is offline
Slight knocking sound for first few minutes driving
Within the last week or two, every morning or evening when I begin to drive my car, it will make a slight, but noticeable knocking/ticking sound. It doesn't make the sound when at idle, or at a slow progression, but when you begin to add pressure to the accellerator.
Yet after a few minutes of driving, it goes away.
98 Honda Civic LX Sedan
Any suggestions....
Thank you for your time in advance...
SJ
Old 02-03-2005, 03:58 PM
lorunner lorunner is offline
Re: Slight knocking sound for first few minutes driving
Maybe piston slap or loose valves. Remember when metal heats it expands so thats why it gets quieter as you drive.
Stop asking me about radio codes I cant get them anymore!!!
Old 02-04-2005, 05:48 AM
exman98 exman98 is offline
is it bad to drive your car hard when the engine is still cold then.
so you are asking me what should you make? Ummmmm.... well i vote meth lab.....helps out the community and gives people like you a job
I love out driving people.
"what's all those cylinders for anyway"
Old 02-04-2005, 03:00 PM
97CivicX's Avatar
97CivicX 97CivicX is offline
Send a message via AIM to 97CivicX
Re: Re: Slight knocking sound for first few minutes driving
it's not bad but its not good either. i think if you let your car sit for a minute or two and dont redline within the first 3 minutes of driving your car will be warmed up and you can beat on it all you want. but i've never heard of anything going wrong with a car solely because someone drove it hard from the start. look at people with automatics. lazy fucks just turn it on and go and wonder why the heat isnt working...
D16Y7/D16Y8 mini-me swap
turbo coming this summer
Old 02-04-2005, 11:48 PM
i have noticed that my vtec will not kick in untill its warm though, or atleast i dont hear it. Is the oil pressure related to heat also?
Old 02-05-2005, 07:39 PM
97CivicX's Avatar
more than likely. the oil cant flow as well as it can when heated so it doesnt engage vtec. what kind of oil are you using?
Old 02-16-2005, 09:23 PM
crownedroyal crownedroyal is offline
Its sounds like piston slap. Honda stats that piston slap is normal on all there cars for the first minute of operation. Anything more than a minute is considered excessive.
Old 02-19-2005, 08:05 PM
Geeko Geeko is offline
Send a message via ICQ to Geeko
yeah, i get that, especially when it's cold outside.
last few weeks, damn thing sounds like a diesel when i start it up.
it DOES fade, though... my dad referred to it as the "honda knock"- apparently a normal thing, even for 3-4th gen civics
BD (Before Deer): Clean... Very Clean.
AD (After Deer): Nascar Ready.
Go Baby Go.
Old 06-13-2005, 10:57 PM
Slight knock
Thanks for your responses... This knocking sound is annoying. I do not beleive that it has to do with warming up, UNLESS, the engine cools down very fast. I drove the car 30 miles on the freeway... pulled in to the store to get a DVD, and got back into the car and it done it again. It lasts for a couple minutes.
Is there something to do to find out if this classifies as the 'Honda Knock' or is something failing? Someone mentioned that Honda's timing belts go out around 90K... I have 88K. What are the symptoms of the timing belt going out?
Thanks in advance for your comments...
Sam
