I have a 93 Lincoln Continental it has been using alot of gas I I dont know why if there is anyone that would know why this is happening please let me know I also have a misfire problem I have tuned the car up many times my lincoln has a brand new engine in it every time I replace the plugs and wire it goes a way for about 4 months then comes back I only buy the best in wires and plugs Please help me out
93" LINCOLN CONTINENTAL 69" BUICK RIVIERA 1988 MAZDA B2200 NEEDS HELPhttp://www.geocities.com/jjbannon81/69RIVIERA.html 1999 OLD ALERO
Re: Burnning alot of gas ???
I think these Lincolns were made to see how sanctified a man is. The only thing I can think of is the 2 oxy sensors 1 in front and one at back of eng also you said you have replace spark wires. Maybe close to heat source . If so maybe extra insulation between wires and exhaust This 92 hasn"t had problem like that/but had olds that I had done every thing I knew I raised the hood on a dark night it looked like Christmas fire running along wires This was after car ran about 1/2 hr.good luck Ringo7 |
thanks I was thinking the same thing about the plugs be a little close to the manifold but now that you said it makes it seem that much more possible
thanks
You also might want to check the coil pack to see if it is bad. That would explain why it keeps misfiring. I like to say that God put two things on earth that a man will never understand, a woman and a Lincoln Continental.
Thanks Mathew The Coil Pack Was Replaced About 1 Yr Ago I Agree 100% To What You Said....
