Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 02-01-2005, 05:54 PM
Carfreak18's Avatar
Carfreak18 Carfreak18 is offline
Send a message via AIM to Carfreak18
Heard Work for turboing
Do you have to do any work to your heads IF you want to turbo or supercharge your vehicle?And also I heard you need a stronger transmission..can you Get it rebuilt or do you need a whole new one. Thanks Guys
Holland Speedway
Lake Erie Speedway
Tioga Speedway (R.I.P)
Wyoming County Speedway
Lancaster Speedway
Motordrome Speedway
Mountain Speedway
Eriez Speedway
Stateline Speedway
Many more to come....
Old 02-01-2005, 11:18 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: Heard Work for turboing
What kind of car are we talking about here?
Old 02-02-2005, 02:51 PM
Carfreak18's Avatar
Nothin special, just cars in general.....Not like race cars or anything if thats what you think im getting at.
Holland Speedway
Lake Erie Speedway
Lancaster Speedway
Motordrome Speedway
Mountain Speedway
Eriez Speedway
Stateline Speedway
Old 02-02-2005, 03:19 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
other than like new valves and valve springs, you dont really need to do anything do you head like porting or anything. porting is pretty much just to get more hp out of your setup so you dont need to run as much boost.
honda trannies are pretty strong, i konw people pushing over 500whp on stock b series trannies, only thing they did was add an lsd, stock diffs are weak
Team Lonely Drivers
Old 02-02-2005, 03:50 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Headwork isn't necessary for boosting a motor. The only time doing some headwork would really be completely necessary is if you've exhausted all other options and still want more power or you floated a valve or something from revving too high. Cams, cam gears, and new valve train can net you 40+ whp depending on the specs of each.
Building up the block is completely necessary if you want lots of power. Forged pistons, conrods, and re-sleeving the cylinders is a must for higher hp applications.
Empty Pockets Racing Member #1
