Old 02-01-2005, 05:25 PM
turbo ES turbo ES is offline
which plug wires should i get
i cant decide to get ngk plug wires or autolite or oem ones. is there any noticeable diffrence in them ngk is about 30 to 40 $ more than oem.
Old 02-01-2005, 05:37 PM
3KSL95's Avatar
3KSL95 3KSL95 is offline
Send a message via AIM to 3KSL95
Re: which plug wires should i get
NGK ALL THE WAY, if i were you i would just go with the full msd ignition if your planing on boosting above 12psi.
1995 3000GT SL (RED)
My mods:
Custom true dual exhaust with x pipe
K&N FIPK
17 inch forged aluminum billet rims from WELD EVO
Old 02-01-2005, 06:12 PM
i dont have turbo its just a wish. everybody says just get a vr4 but i got my stealth at a junkyard for 1100$ with a bad engine and put about 1400$in it so if i could find a supercharger kit thatd be great. but havnt heard good things about the ones that fit but id be plenty happy with runnin 14s and its an auto. so i might just do some of the things you did and see what i come up with was the under drive pulley worth it.
Old 02-01-2005, 08:39 PM
Igovert500's Avatar
blue + red light magnet
"I looked at several after-market spark plug wires but ended up buying OEM.
The main reason to get after-market wires is because you want to dress up the engine
compartment with a wire color other than black. The resistance per length of wire is
less on most after-market wires but nobody has been able to document any
noticeable change in performance. The stock ignition system does not make enough
spark to require heavier wires. Several people have added after-market ignition
amplifiers but the results do not appear to be worth the large cost in my opinion.
The aftermarket coil kits do seem to allow a larger spark gap with out spark blowout
So I will probably do this upgrade in the near future"
Taken from John Monnin's plug comparison...if you want to read more, here is the link:
http://johnmonnin.netfirms.com/PlugWires.html
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 02-01-2005, 09:41 PM
Gateway's Avatar
Gateway Gateway is offline
Magnecor KV85 8.5mm sitting in a box for about 11 months now. As soon as I get my tax refund I'm getting a tune up and getting these installed.
'92 3000GT VR4
Current Mods:
K&N FIPK
RPS Streetmax clutch
Rebuilt tranny
Free Boost Mod
Maximal Performance Solid Motor Mounts
Pictures and Videos of my car
Got a question about your auto insurance? I'm an insurance agent, ask away.
Old 02-01-2005, 10:47 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
MSD has the lowest resistance of any wire out there. Pair that with a non-resistor plug and you get the best possible spark without better coils.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
