Old 02-01-2005, 04:43 PM
Vtec95Civic Vtec95Civic is offline
O2 sensor WILL NOT come out..
So I hada CEL go on a few weeks ago.. had to replace the O2 sensor.. the problem is I can't get the old one out!
I tried myself, then brought it to a mechanic. He poured on the WD40, heated it with a torch, the sucker would not move. He said the best best would be to get a new manifold... or.. the way I'm leaning.. some headers and put the new one in with them.
How much is a new manifold from Honda? Would it be smarter to put in the headers (cost wise). I wasn't planning anymore performance mods for this car, because I want to sell it for something faster.
Old 02-01-2005, 07:15 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
Have you tried using an impact wrench on the O2 sensor? I had one on another vehicle that was really stubborn that needed a big impact to get out.
If you need to replace the manifold, a junkyard one may be the cheapest, otherwise a header would cost less than a new honda manifold. The only thing to watch out for with a header is the pipe diameter, it might not bolt directly to your exhaust system.
Old 02-01-2005, 07:21 PM
No he didn't try an impact wrench.. tried a blowtorch though.. that was interesting..
Old 02-01-2005, 07:23 PM
Miataracer's Avatar
Miataracer Miataracer is offline
Send a message via AIM to Miataracer Send a message via Yahoo to Miataracer
Re: O2 sensor WILL NOT come out..
try the impact wrench idea. they also make a special socket for use with o2 sensors that has a cut on the side for the wires. may want to check into that
LS1 RX-7 Zoom Zoom
Old 02-01-2005, 07:25 PM
I was using the O2 sensor wrench.. nothing.. I mean we're talking about a 200ish lb guy putting all his weight into turning that nut.. nothin doin.
Old 02-01-2005, 10:25 PM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
I had to use the arm off my jack. You really need good leverage on it. But I also let WD40 soak in for about 30-60 minutes.
I actually took my whole exhaust manifold off and wedged it against my tire of my car to get some good leverage.
After you get it off remember to add some anti-seize compound to the threads.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 02-01-2005, 10:26 PM
Mingish's Avatar
Mingish Mingish is offline
i had a problem getting one of my rotors off...tried everything with no luck...a guy came over with an impact wrench and came off first try. There a handly little tool for sure
Old 02-02-2005, 12:00 PM
For getting out the old sensor, cut the wire right next to the sensor so a normal socket will fit over it. And use an impact. Taking off the manifold seems kinda extreme if you can get your hands on an impact, and the exhaust manifolds are so thick that you'd be hard pressed to heat it enough with a torch to make a difference.
Old 02-02-2005, 06:04 PM
97CivicX's Avatar
97CivicX 97CivicX is offline
Send a message via AIM to 97CivicX
i ended up sawing mine in half so i could fit a regular deep socket over it, then managed to get it off with just a big ratchet
D16Y7/D16Y8 mini-me swap
turbo coming this summer
Old 02-02-2005, 06:55 PM
Civic Mod
Re: Re: O2 sensor WILL NOT come out..
That impact driver is different tool than an impact wrench.
Autocross Help Page
Buy my Civic parts!
Old 02-02-2005, 08:48 PM
I can't cut mine though.. because if I cut it and it still doesn't come off then I'm really screwed.
Old 02-02-2005, 09:11 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
check out the socket that miataracer is talking about. rent an impact wrench and get an adapter if you need one to get that socket to fit and have at her.
Empty Pockets Racing Member #1
