Old 02-01-2005, 03:55 PM
BoNkA10 BoNkA10 is offline
Send a message via AIM to BoNkA10
Ground Control with which shocks?
I'm looking at getting GC coilovers to lower my car probably 1.5". I was wondering if I should keep my stock shocks or get new ones. I know I saw that they don't last very long, making it seem like it'd be worthless to get them, but that would also mean mine have been shot for a while, being 6 years old. I'd also like to keep the amount of money I spend to a minimum since I'm planning on dropping a bunch on audio, security, wheels, and exhaust system as well.
1998 Eclipse GS
Old 02-01-2005, 04:36 PM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
Re: Ground Control with which shocks?
You will want new ones for sure. Especially if you want to be able to launch half decently. Using soft shocks with hard springs will also cause damage to the shocks and they will have to be replaced eventually anyway. Depending how hard the springs are and what not, it may get to the point where you bend arms, not in two days or anything but over time. As well, you increase your ease of bending a rim. It is important to get new shocks, but if you let your stock ones wear out first then get new ones you should be okay.
"You can have everything in life you want if you will just help enough other people get what they want."
Old 02-01-2005, 04:41 PM
Are the Tokico Illuminas the best match for the GC?
1998 Eclipse GS
Old 02-01-2005, 05:09 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
I think 95 GSXracer would say so, as he runs them. He has explained suspension several times on this board, give search a try -- i bet you will find them. He explains his opinion on spring rates front and rear as well as a lot of other helpful aspects of choosing suspension components.
Old 02-01-2005, 05:23 PM
I read his big post on all that. So basically I'm looking at probably 450 front, 350 rear spring ratios (if I read that correctly)? And it seems as if I'd have to get the upper mounts? More money I don't really have to spend.
1998 Eclipse GS
Old 02-02-2005, 06:00 PM
I'm still kind of lost on this stuff...
1998 Eclipse GS
Old 02-02-2005, 06:14 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Re: Ground Control with which shocks?
Yes, if you use the car the way I do. Some people go up to 700 pounds or more for autox, while 600/500 seems fairly common for it as well. But you wont run those springs on tokicos. 450/350 is good for a mostly street car, and is pushing the limits of the tockicos.
The mounts are only 100 per end. The fronts are the only ones that are REQUIRED if you want to cheap out. But I'd rather spend the rear 100 for the sake of do it right, do it once. But the fronts are required in my most humble opinion.
I got out of it all for 1050 at the time. These days it may make more sense to spend a little more and do something like Tiens. Though I'm not completely sold on them, but I'd like to get some firsthand experience with them. Odds are I would spend 500 more and just do JICs if I ever upgraded, setup by RRE. Some good info on their page if I remember correctly.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 02-02-2005, 06:24 PM
So which shock would you suggest? (sorry but not sure exactly what the Tiens are)
This is basically just a daily driving setup, no intended racing, so the 450/350 is ideal? Or should I lower that and run on the Tokicos.
1998 Eclipse GS
Old 02-02-2005, 06:34 PM
AF - Advisor
You could drop to 450/300 if you dont plan to race or take corners hard, the rear shocks will last longer.
The tiens are a shock/coilover combo, what some poeple refer to as "true" coilovers. I think its around 1200, everyone has a boner for them, but I dont know what spring rates are available. In your case you could most likely go with the "stock" setup though.
Suspension is all about money. There is no magic way out of it. Since you dont seem to need a specific spring rate, you could spend less money on regular 1.5" shocks like Eibach sportlines and tocikos if you dont need to adjust height, but I'm not sure if the front upper mounts are compatible. If not, you'll be riding on the front bumpstops like everyone else Be sure to cut them at least. But if you arent pushing the car hard in the corners, you may not care anyway. That would drop it down to 600 bucks or so...
I would look at how much money you have/want to spend, and how much suspension you really need. Its a pretty important decision, once that you hopefully only make once.
Kevin Jewer
Old 02-02-2005, 06:42 PM
Yeah, all I'm interested in doing is dropping the car probably 1.5 inches, 2 at max.
What would be included in that "600 bucks or so..." ?
But it seems like I could just go with the GC coil overs, get the upper mounts, and get the Illuminas and go 450/300 and I should be ok?
1998 Eclipse GS
Old 02-02-2005, 06:44 PM
AF - Advisor
Springs and shocks.
Absolutely. Its a well proven setup.
Kevin Jewer
Old 02-02-2005, 07:21 PM
Forgot to ask, where should I look for the upper mounts? Thanks for the help, too.
1998 Eclipse GS
Old 02-02-2005, 07:28 PM
AF - Advisor
Ground Control offers them, you can order them with the coilovers.
Kevin Jewer
Old 02-02-2005, 07:39 PM
Just checked their site and found them, only thing is it says 95-99 DSM Front Upper Mount (requires 1' longer front spring). Same thing for the rear. 1' longer??
1998 Eclipse GS
Old 02-03-2005, 06:53 AM
Still have no idea about that 1' longer spring deal.
But how would this work? http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
It's "These are brand new in the box a set of 4 ( 2 front BU3532 Shocks and 2 rear BU3534 ) TOKICO ILLUMINA 5 WAY EXTERNALLY ADJUSTABLE struts / shocks and 4 High Performance Lowering springs with a 1.5 inch drop." for $440 + $15 shipping.
1998 Eclipse GS
