Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-01-2005, 02:41 PM
GTPSPEED GTPSPEED is offline
BOSTONjoe98gs
code read help,thanks
first off hello everyone as you see we had alot of snow,ok well my check engine light came on so i had it read it said p1494 spcut solenoid circuit malfunction,so i know its the solenoid but is it cheap or is it easy to fix,let me know ok because i will do it myself if it is easy to replace if not i hope it is cheap i had a bad couple weeks so it will suck,ok people thank you bye
2000 GRAND PRIX GTP RED 14.345 @97.8mph
ubend delete
3in jimmyC downpipe
magnaflow high flow cat
Joeflo CIA (made it myself)
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
ss 409 xl turbo mufflers
Old 02-04-2005, 09:25 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: code read help,thanks
No need to be a smartass about it! ["Pointless to post this in the problem diagnosis subforum"]
Maybe no one knows what code that is... Looks like a speed cut solenoid. Do not quote me on that cause I'm not sure either. Call the dealer and find out what it is.
Old 02-08-2005, 12:44 PM
BOSTONjoe98gs
ok dont want to be a smartass but is that not a problem,well anyways i will use the advise and call the dealer and see if they know
ubend delete
3in jimmyC downpipe
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
