Old 02-01-2005, 01:23 PM
JoshBarber JoshBarber is offline
Question gas mileage
Currently getting 12.5 mpg city. Granted it's been real cold out lately.
This time I purposely didnt let it idle for periods of time to be more accurate.
I see a lot of others says 13-15 city and 20-26 highway.
Am I far enough off so I should think theres an issue?
I've done PCV, Fuel Filter, & Air Filter. Engine is running smoothe so I'm trying to avoid doing plugs and wires till it's a little warmer out. Low on cash too.
thanks
J
Old 02-01-2005, 01:42 PM
Re: gas mileage
Holy crap~!
I just read the 98 4.3 LT takes 4 02 sensors! 2 on each side. 2 in front of the cat, and 2 in back!
At $53 a piece (which is cheaper ones) that's over $200!!!!!
Anyone done all four? Anyone notice a difference in mileage?
Old 02-01-2005, 02:15 PM
molehole's Avatar
molehole molehole is offline
Send a message via AIM to molehole
Re: gas mileage
I would imagine if the O2 sensors were bad you would be getting a check engine light. How many miles do you have? Once you change the plugs, wires it may go p quite a bit. Try running some fuel injector cleaner through it and see if it helps. Try LUCAS fuel injector cleaner- it works pretty well. Good Luck
Old 02-01-2005, 04:07 PM
Re: Re: gas mileage
thanks, I actually recently (over a week or two) ran the lucas injector cleaner through. So I guess I should poney up the dough for the wires/plugs. Just was living my the old "if it aint broke, don't fix it" oath
Old 02-01-2005, 04:50 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: gas mileage
You need to look at the following:
Plugs
Cap & Rotor
I would at least swap in a new cap and rotor if it hasn't been done.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-01-2005, 05:53 PM
Re: Re: Re: gas mileage
I thought you didnt have a cap and rotor if it was fuel injected?
Old 02-01-2005, 05:59 PM
BlazerLT's Avatar
AF -Advisor
Re: gas mileage
It has one, you should replace it.
Old 02-01-2005, 06:02 PM
Re: Re: gas mileage
is that normal for fuel injected vehicles?
Old 02-01-2005, 08:23 PM
BlazerLT's Avatar
AF -Advisor
Re: gas mileage
Some, fuel injection NEVER means you automatically don't have a cap and rotor.
Never assume that.
Old 02-02-2005, 10:47 AM
buckeyboy buckeyboy is offline
Re: Re: gas mileage
Never assume that.
Blazer LT is correct. It does indeed have a cap and rotor . Note: you will need two different size torx drivers two remove the cap and rotor ,wires have numbers on them so does the cap which makes it nice.
Old 02-02-2005, 03:42 PM
metallica21156's Avatar
metallica21156 metallica21156 is offline
Re: gas mileage
i just changed my CPI and Nut kit. tune up with plugs,wires,cap,rotor. i still get 12-13 MPG. grant you its cold but i think it should be doing better then that. and air filters clean and 2.5" cat back so theres plenty of flow. any reason on why still bad gas mileage? and the CPI or nut kit arent leaking.
95 jimmy. Vortec V6. 4.3 liter CPI. ,2.5" catco cat, 2.5" cat back with flowmaster muffler split rear., 40 street series, 2 12" audiobahns in custom box,K&N CPI intake system.
71 Mustang coupe- project car. stock 302 with Cobra intake, holley 650dp, afco racing radiator, headman headers, msd distributor, 2.5" from the headers.C4 tranny with shift kit, Mach 1 body lay out.
90 cav, 2.2 tbi, gas getter.
99 chevy s10 zr2, 6" lift, duel exhaust. 5 speed.
Old 02-02-2005, 03:45 PM
Re: Re: gas mileage
4 02 sensors.....................be prepared to pay $200 at the least for just the parts to do it yourself. I think we'd have trouble codes if they were bad though. How's your tire pressure?
Old 02-03-2005, 03:01 PM
O2 sensors might have 3,000 miles on them. tire PSI is to what the tire says. any ideas?
Old 02-03-2005, 04:12 PM
BlazerLT's Avatar
AF -Advisor
Re: gas mileage
How are you calculating the fuel economy?
Also, is this stop and go city driving?
Old 02-04-2005, 10:16 AM
Re: gas mileage
i drive 3-4 miles each way to work. average speed is 45-55. 45 going and 55 coming home. almost no stop and go traffic. i got the numbers by filling the tank. driving 40 miles and then refilling the tank and taking down the number of gallons and deviding it into the miles driven.
