Old 02-01-2005, 10:37 AM
gasman19772000 gasman19772000 is offline
programming keyless remote for 97 camaro
I need instructions on how to program keyless remote for a 1997 camaro. Help.
Old 02-01-2005, 01:58 PM
cuda_dude cuda_dude is offline
Will Whore For Car Parts
Send a message via AIM to cuda_dude
Re: programming keyless remote for 97 camaro
1996-1997 Keyless Entry Programming
Programming procedure:
Turn ignition switch to OFF position.
Remove RADIO fuse 17 from fuse block.
Cycle ignition switch from OFF to RUN three times within five seconds until the door locks and the hatch release cycle, indicating the Body Control Module is in the Programming Mode.
Press and hold BOTH LOCK and UNLOCK buttons on remote control door lock transmitter for 16 seconds.
Door locks will cycle once, confirming the transmitter code is programmed. The door locks must cycle completely to unlock before proceeding.
Any transmitter code that was previously programmed has been erased.
Body Control Module is now programmed to remote control door lock transmitter.
When programming the Body Control Module to match remote control door lock transmitters, the first transmitter code matched will be stored in memory unless a second remote control door lock transmitter is matched at the same time. If programming the Body Control Module to match a second transmitter, repeat step 4. This must be done before the RADIO fuse 17 is reinstalled.
Ignition switch to OFF.
Reinstall RADIO fuse 17 to fuse block.
NOTE: Always program both transmitters when replacing a lost or damaged transmitter. The first transmitter code programmed will always be in both memories until a second transmitter is programmed within the same sequence.
1995 Camaro - Z28 - M6 - Hardtop
2007 GMC Sierra 2500HD SLT Classic
-R.I.P. Andy (Hypsi)-
Old 02-01-2005, 02:10 PM
Thank you very much. I will give it a try.
