Go Back   Automotive Forums Car Chat > Ford > Econoline
Old 02-01-2005, 07:50 AM
ACE1797 ACE1797 is offline
96 E-250 Heat Problems
mY 96 E-250 HEAT WORKS GREAT WHEN IT BLOWS HEAT. IT WILL BE WORKING FINE BLOWING HEAT, THEN IT GOES COLD. IF I PLAY WITH THE TEMPERATURE SWITCH ON DASH THE HEAT USUALLY WOULD COME BACK. NOW IT DOES NOT IT ONLY BLOWS COLD. I TOOK THE DASH APART HOPING THAT THE MANUAL SWITCH WAS UNHOOKED BUT IT IS ELECTRICAL. I PULLED OUT THE CIRCUIT BOARD AND TESTED IT BUT IT SEEMS FINE. ANY HELP WOULD BE GREAT. I DON'T KNOW IF THE BOARD IS BAD OR IF THE FLAPPER MOTOR IS BAD OR HOW TO FIND IT AND CHECK IT. THANK YOU
Old 02-01-2005, 08:15 PM
jspence35 jspence35 is offline
Re: 96 E-250 Heat Problems
this year commonly broke the blend door at the point where the eletrical motor goes in
