Old 02-01-2005, 03:59 AM
texwill texwill is offline
94 Blazer cuts off????
OK, something weird is going on with my truck. Every once in awhile my I will be driving the Blazer and it goes totally dead for a split second, all dash lights go off and motor dies, then in the same second, everything cuts back on including engine. I do not have to recrank the motor or anything, it simply shuts off totally for a split second then turns back on. Anyone know how to fix this? What the problem is? 94 Blazer 4.3L Vortec 4 door.
Old 02-01-2005, 04:09 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 94 Blazer cuts off????
I would have to say ignition or a bad ground.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-01-2005, 07:24 AM
Bad ground? Like from the battery or somewhere else?
Old 02-01-2005, 07:34 AM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
The first thing I'd suspect would be the ignition module in the distributor. You used to be able to have the checked at Autozone, but the stores in my area stopped checking them. Take the truck to Autozone and have them check for any codes.
Old 02-01-2005, 07:36 AM
I would but I am stationed in Germany right now and there are not any of those here!
Old 02-01-2005, 07:41 AM
Realitydept Realitydept is offline
Re: Re: 94 Blazer cuts off????
if the dash and everything goes dead, its a larger problem than just the ignition module. I'd start by pulling the battery cables and checking/cleaning/retightening them, then check the ground cable where it bolts to the engine.
Old 02-01-2005, 07:56 AM
Big Tall Dumb Ass
You're right, this is almost sounding like the Pink wire in the ignition switch dilema again.
Old 02-01-2005, 08:36 AM
ok so all of the terminals and the ground is tight, now what should I check?
Old 02-01-2005, 08:46 AM
sounds like a bad ignition switch
