| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
Couple Minor Problems
Re: Couple Minor Problems
to get rid of the cat code you can do a couple things. 1 buy a o2 simulator for 400 bucks
2 take out the second o2 sensor and wrap it in aluminum foil and then put it back in. this block it from being able to read which is good since with a cat the second o2 sensor never sees anything. 3 you can also leave the 2nd o2 out but then you need to plug the hole for it or your exhaust will sound crappy
-1stGenRocks- 95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's plans: bastard 20g, water/meth injection NO FMIC |
Ok thanks, I'll be doing number 2 tomarrow morning then. Thanks again.
