Old 01-31-2005, 10:01 PM
mcgyver mcgyver is offline
95 cavalier no power
My 95 with 2.2 starts and idles fine but when you take off down the road it lacks power (doggy) unless you kick it in the a!$, if you do that it takes off fine. After you drive it for a half hour or so you can feel it come out of it and it runs fine. I get a check engine light just before it straightens up and the cooling fan cycles on and off continually. Any suggestion? Thanks in advance..
Old 01-31-2005, 11:56 PM
noshun's Avatar
noshun noshun is offline
Re: 95 cavalier no power
Have you coded the car? It's sounds like a bad sensor with the fan and all. But if that is a seperate problem and just coincidence that it's happening simultaneously then I would guess at Fuel delivery problems. Possibly the fuel pump itself, maybe just the fuel filter or gummed up lines that need a cleaner run through them.
Red Z24 = Dead, 03 2 door = 15.5 with no traction. low 15's here i come
'Never forget Grasshopper, Not speed, smile!'
