Old 01-31-2005, 09:18 PM
andre2great andre2great is offline
Unhappy Fuel Pump Has No Power!
i have a 1990 v6 dodge caravan 3.0l, i tested the pump to see if i haad power to it, with a tester and nothing came up, can anyone please help me on this, wheres the fuse link located. i really need some help.i cheacked the relay it's working, any ideas will be a big help.
Old 03-27-2005, 08:45 AM
thangfish thangfish is offline
Wink Re: Fuel Pump Has No Power!
You DO realize that the fuel pump only gets power for a second or two by a timer when the key is turned on, but engine is not started?
To test this, be looking at your voltmeter / testlight while someone else turns on the key. If you get power and it quickly shuts off, you're good.
Your problem is probably the pump itself or the connection. The way that connector is designed, it's very easy to plug it in and have one of the prongs shoved up in the rubber plug, along side the actual metal socket, instead of IN it. This will work for a little while, but not for long... I know from experience!
