Old 01-31-2005, 09:13 PM
Old and good Old and good is offline
Send a message via MSN to Old and good
air filters
i just installed a ebay cone air filter system and to my surprise the engien sound dramaticly changed! i now notice a drastic change in rpm ranges and other small changes.
have you guys noticed the same thing?
Old 01-31-2005, 09:33 PM
turbo ES turbo ES is offline
Re: air filters
what do you mean it gets up to redline faster or what i dont have one but if it helps that much i might look into it
Old 02-01-2005, 11:38 AM
Igovert500's Avatar
blue + red light magnet
Re: air filters
It makes your car sound more aggressive, and if you have a TT, it makes turbo spool and the bov more audible...but as far as gains, it is only good for a few hp...nothing drastic.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 02-01-2005, 03:27 PM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
They do help in getting the air flow going which helps the turbo models. Just the first in the line.
Resistance Is Futile (If < 1ohm)
Old 02-01-2005, 06:37 PM
Re: air filters
what i meant is that the engien's rpm range seems to have gotten a bit higher. but im just looking forward to going to the track and check if the 1/4 mile times have changed.
what the hp gains are concerned i think it did not give me to much but i can still feel a differance and the tourqe gains i can realy feel as i was driving on the highway the car actualy was running lower rpm nubers on the same speed as i was driving to the garage (no it was not a hill it was a straight road)
Old 02-02-2005, 12:29 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Re: air filters
well ya...sorta. a cone filter, aka open element air filter, allows your engine to breath easier, especially at higher rpms. oh, and you MIGHT gain 5hp, but that's liberal. don't waste a trip to the track just to test 1/4 mile times. the only time difference you'll see is if you have a TT car, or if in your NA you launch/shift better.
yup, if ya think about it...it makes sense too. with your new filter, you allow the engine to breath easier, that is it can suck in more air w/o having to work as hard. or you can look at it as for a given rpm, it will suck in more air than it would with the stock filter. so you might see a 100 rpm difference, but most likely its quite negligible.
but the cone filter is a great supporting mod for other upgrades like FI and fuel.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
