Old 01-31-2005, 08:35 PM
toenailclippers toenailclippers is offline
Send a message via AIM to toenailclippers
Exclamation What do i need for this?
OK, Ive been putting off a tune-up for TOO long. I know I need the usual, air filter, plugs, wires....but what else is there? Im thinking O2 sensors as well, but ive heard that gets expesive. also would that cause my service angine soon light to come on? what about the coil pack,? IM used to working on pre-1980 vehicles, without all this fancy computer controlled crap. I say F*** emissions and everybody convert their electronic ignition over to points! Anyway, a list of stuff i would need to do an extensive tune-up would be great, that way i can get some better gas milage!
Old 01-31-2005, 08:42 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: What do i need for this?
Do a complete tuneup with cap, rotor, wires, AC Delco plugs gapped properly, PCV valve, fuel filter, air filter.
Also note, might want to do a cooling system flush with a new Non AC Delco rad cap along with a transmission flush and filter change and to drain your tranfer case and differentials and fill them with fresh fluids.
It might seem like a lot, but you can do most of it yourself and your truck will be completely perfect and performing to its maximum potential and will lengthen the life greatly.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-31-2005, 09:59 PM
Bodaggit Bodaggit is offline
Send a message via ICQ to Bodaggit
Why time to zero? I figured there would be no reason to time a new one, I thought the computer would control most of that unless the timing chain was bad or something like that.
Old 01-31-2005, 10:23 PM
BlazerLT's Avatar
AF -Advisor
oops, my bad.
Old 02-01-2005, 10:49 AM
blazee's Avatar
blazee blazee is offline
Problem?
Re: Re: What do i need for this?
What brands of fuel filter do you recommend? I'm ready to change mine again, I perfer AC Delco, but none of the parts stores around here have them, I have to go to the Chevy Dealer ($20) 45 miles away. Any others you recommend or is it worth the trip and the extra money?
Old 02-01-2005, 03:21 PM
where would the PCV valve be located on the engine?
Old 02-01-2005, 03:28 PM
blazee's Avatar
Problem?
Driver side valve cover, It slides in the valve cover and has a hose that slides on it.
Old 02-01-2005, 03:42 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: What do i need for this?
When it comes to fuel filters, it really doesn't matter as long as they are changed every 40,000 miles.
Old 02-01-2005, 03:47 PM
blazee's Avatar
Problem?
Re: Re: Re: Re: What do i need for this?
Thanks, I'll just pick one up at NAPA tomorrow. You have been on this forum a lot longer than I have, I figured I'd make sure you hadn't heard of any problems with the cheap ones first.
Old 02-02-2005, 05:12 AM
ricksza's Avatar
ricksza ricksza is offline
Make sure you use a AC PCV valve. Have had problems with most other brands.
Reason for Electronic ignition over points: the normal point dwell is 30 degrees while the electronic is 45. More dwell equals better performance. OEM high performance had electronic as far back as the 1963.
Old 02-02-2005, 11:55 AM
BlazerLT's Avatar
AF -Advisor
I have yet to see any real difference between Fram, Help, AC Delco or any other brand.
Old 02-02-2005, 11:59 AM
blazee's Avatar
Problem?
I haven't had any problems with my PCV valve. It's deutsch or some thing like that, I got it at Autozone for about $3. I think next time I'll buy a brand I can pronounce, though.
Old 02-02-2005, 12:18 PM
BlazerLT's Avatar
AF -Advisor
Nah, as long as it rattles and as long as you replace it every 2-3 years, you will be fine.
Old 02-02-2005, 02:09 PM
ricksza's Avatar
You'll notice at an idle sometimes, the other brands will buzz. Sometimes they flow too much acting like a vacuum leak. I'll stick with OEM for my PCV valve.
