Go Back   Automotive Forums Car Chat > Honda > Integra
Old 01-31-2005, 09:18 PM
z_integra z_integra is offline
Send a message via AIM to z_integra
Why Is My Integra Shaking?
I Own A 94 Integra, Its An Auto And Runs Fine Until About A Week Ago My Car Started To Shake Now Everytime I Drive It When I Come Up To A Stop Sign Or Light The Car Idels At 1000 Rpm But Shakes Like It Wants To Stall I Have No Clue What It Could Be If Anyone Know What I Should Do Please Say So
Thanks!!!
Old 02-07-2005, 10:44 PM
TypeGsR TypeGsR is offline
Banned
Re: Why Is My Integra Shaking?
idle pretty high on ur throttle body there is a screw either screw it in inwards our outwards and it wont idle as bad or its either a IAC idle air control honda famous for them going bad
Old 02-09-2005, 09:18 AM
madmaniac madmaniac is offline
this started happening on my girls car last night. tag for more info.
96' se auto
Old 02-09-2005, 01:49 PM
dopenoze dopenoze is offline
do you have an intake or a filter on it? mine did that for a couple weeks after i put on a cai but my idle was low like around 600rpm.
Old 02-17-2005, 05:24 PM
95RSV's Avatar
95RSV 95RSV is offline
I think I have this problem too. When my car idles at 1000rpms my engine rattles like hell. Even when at a red light the odd time it would feel like my car will stall.
Tsudo N1 Catback
Custom 4-2-1 Header
Custom Hi-Flow Cat
Custom CAI
Exedy Organic
Fidanza Flywheel
NGK Iridium
Tokico HP Suspension
ADR DV8 Sandblack Rims
Nankang NS-1 Rubber
Old 02-17-2005, 06:48 PM
kornflakes28546's Avatar
kornflakes28546 kornflakes28546 is offline
are all of your cars auto? the one with the intake... try resetting the ECU i think that should fix the problem. my 5-speed idles anywhere from 700-2200 depending on the temperature.
Old 02-19-2005, 11:51 AM
95RSV's Avatar
Re: Re: Why Is My Integra Shaking?
How do you reset the ecu? I hope you don't have to go to the dealership or something
Tsudo N1 Catback
Custom 4-2-1 Header
Custom Hi-Flow Cat
Custom CAI
Exedy Organic
Fidanza Flywheel
NGK Iridium
Nankang NS-1 Rubber
Old 02-19-2005, 12:04 PM
p0wered_by_acura's Avatar
p0wered_by_acura p0wered_by_acura is offline
take off the negative on your battery...then put it back on and turn your car on....let it idle for about 10 mins to allow time for the ecu to collect the information again
Old 02-19-2005, 03:04 PM
slow_99integra's Avatar
slow_99integra slow_99integra is offline
this happened to me. it was my idle control valve. make sure all ur vacuum lines are connected and no wires are kinked. i just disconnected and reconnected and it idled fine. is the check engine light on??
Old 02-19-2005, 03:17 PM
CBURKE's Avatar
CBURKE CBURKE is offline
yes check you vacum hoses!!!
also look at your motor mounts. if they are going bad or thay are bad it will shake like hell when you are at a stop or coming to a stop. it may just be your idal cv.
98 MITSU GST, 1990 TURBO MOTOR
98 ACURA INTEGRA LS
88 HONDA CIVIC HB
97 HONDA CBR 600
91 HONDA CRX DX
89 JEEP
