Old 01-31-2005, 08:02 PM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
Oil Pressure Gauge Issue
Hey Guys!
Quick question...
I just had a JDM 6 bolt swap done on my car and I have a problem with the oil pressure gauge.
To start off I want to say that apparantly the JDM Engines are all ready to hook up an oil cooler too. Well, my mechanic said that one of the banjo connectors was broken when he did the swap so he took an adapter off of my old engine (not sure what) and put it on there so it would work. Now, he said that may be restricting a little bit of oil flow but not much. The end of the story is that my oil pressure gauge is showing no oil pressure. Other people that have had this swap also have this happening to them. I am sure that the engine is making oil pressure, but is there anything I should be worried about, or anything I should check to make sure all is good?
Let me know what you think please.
Thanks!
Alex
"You can have everything in life you want if you will just help enough other people get what they want."
Old 01-31-2005, 08:27 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: Oil Pressure Gauge Issue
make sure the sender is there and is plugged in.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 02-01-2005, 11:15 AM
gsxeclipse97 gsxeclipse97 is offline
Send a message via AIM to gsxeclipse97
How much did the swap cost all together
Old 02-03-2005, 09:02 AM
bighauns's Avatar
Update--> The oil gauge went up for a bit and then down twice today. This gives me the idea that is may be an electrical issue. Do you think that is possible? I will check the unit later today.
Old 02-03-2005, 05:03 PM
kjewer1 kjewer1 is offline
AF - Advisor
Get an aftermarket electrical gauge, much more useful. Summit has the autometer sportcomp for ~40 bucks, thats what I use. In fact I only have 2 guages, boost and oil pressure
I would have rather had the housing for the external cooler, even if you block those ports off with a bolt or apapter fitting/cap. The 91-94 sandwich cooler (aka "oil mixer") is a huge POS and cost me my 2nd or 3rd motor. But you can deal with that later. As long as the housing used fits the front cover on that motor, it should be fine. I'm not sure what the mechanic meant by oil resitrction.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 02-03-2005, 06:25 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
Kevin, Im assuming that your oil pressure gauge is mechanical. I ahve heard of safety issues on these gauges...hot oil may shoot out of the gauege while driving.
Some technical help would be appreciated.
The daily driver. The weekend cruiser. The lazy shop hog.
Old 02-03-2005, 10:25 PM
bighauns's Avatar
Re: Re: Oil Pressure Gauge Issue
Sorry, I don't know if it is because it is late or what, but I am totally confused as to what I should do or what you said. I am sure it makes sense, just please explain it to me a little further. Thank-you.
Old 02-03-2005, 11:13 PM
AF - Advisor
I use an electical gauge. That was the suggestion in the first line of my last post
Forget everything I said about the oil filter housing. I dont have the energy to explain further, and odds are you arent going to change it anyway
Kevin Jewer
Old 02-05-2005, 01:38 PM
bighauns's Avatar
I still would not mind a little info if you ever get a chance. But thanks for the help
