Old 01-31-2005, 08:59 PM
Huckleberry97 Huckleberry97 is offline
95 F-150 Clutch pedal stuck to floor
On the way home from work, the clutch pedal felt soft but everything shifted fine. I checked the fluid reservoir and it was only about 1/2 inch low. The next morning, I depressed the clutch to start the truck and the pedal didn't come all the way up (but everything still shifts into gear fine). I tried lubricating all moving parts associated with the clutch pedal hoping this was a simple fix. Unfortunately, the pedal is still on the floor. I have not driven the truck since noticing this problem. Any suggestions?
FYI - The truck has 110,000 miles on it.
Any help is appreciated!
Old 02-01-2005, 04:44 AM
FORDTRACMAN FORDTRACMAN is offline
Re: 95 F-150 Clutch pedal stuck to floor
Try bleeding slave cylinder.
Old 02-01-2005, 10:35 PM
w8crz's Avatar
w8crz w8crz is offline
Send a message via MSN to w8crz Send a message via Yahoo to w8crz
how about the auto adjusting pedal gear under the dash?
1991 F150 4X4
302 cid
AOD Tranny
My everyday, all weather 245,000mile truck
Old 02-05-2005, 08:23 PM
Was finally able to get under the truck today. Slave cylinder is leaking. Clutch is close to needing replaced so I will drop the tranny and replace everything.
Thanks for your suggestions!
