Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 01-31-2005, 08:24 PM
SenseiAccord SenseiAccord is offline
Aftermarket Radiator cap
does anyone know or think that getting a radiator cap with a higher pressure will put stress on the cooling system since it rasies pressure? i kno it will raise the boiling point but will it like expand the hoses or weaken the radiator or something since the pressure is going from like stock 14psi to 18psi?
Old 01-31-2005, 09:32 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
Re: Aftermarket Radiator cap
Why?....dont waste your money.
2002 Acura TL Type S
1991 Honda Crx Si
Old 02-01-2005, 12:44 AM
i dunno... thought i might try it out. I do live in hawaii so the weather does get a lil hot. does it really not make that much of a difference... or even worth the money?
Old 02-01-2005, 01:04 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
what island u from ? ive never met anyone else from hawaii on here. putting too much pressure on other components might cause them to leak, like hoses or water pump gasket.
Team Lonely Drivers
Old 02-01-2005, 04:40 AM
yea i was thinking about that so thats why i was debating on getting one.
anyway... im from oahu
Old 02-01-2005, 07:02 PM
Prelude707 Prelude707 is offline
Send a message via AIM to Prelude707
I've heard that getting stronger upper and lower radiator hoses is all you need to run the higher pressure safely. I would like into stainless steel braided hoses.
2000 Honda Prelude
Mod list-
AEM CAI, AEM underdrive pullies, AEM FPR w/fuel rail, AEM brake pads, Apex'i N1 catback exhaust, Random Tech Hi-flow cat, Autometer fuel pressure & A/F ratio gauges, Apex'i VAFC(dyno tuned), ACT Xtreme pressure plate w/street disc and streetlite flywheel, Zex wet shot w/dual bottles and purge, Neuspeed front strut bar, VIS EVO CF hood, Honda Access door sills, NX bottle warmers, Lean Racing short shifter
Soon to come-
17" wheels, ES motor mount inserts
