Old 01-31-2005, 08:12 PM
Diesel6987 Diesel6987 is offline
1994 Dodge Ram starting problem
My Dodge Ram will crank and start, but it wont stay running. After you crank it over it will only stay running if you hold the gas and sometimes it will stay idling, but when you drive and pull up to a stop it will shut off. What makes it do that?
Old 02-22-2005, 05:46 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 1994 Dodge Ram starting problem
what have you checked already?
I'd guess maybe the EGR valve sticking open.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
