Old 01-31-2005, 07:41 PM
alpineblazer23 alpineblazer23 is offline
Question 98 Blazer..How to turn off Day Time Running Lights?
Hey i bought a 98 blazer and love it. I want to know how to turn off the day time running lights along with the sensor that turns the headlights on when it gets dark.
Old 01-31-2005, 07:46 PM
swalt's Avatar
swalt swalt is offline
On the left side of your dash there is a dome override button. Push it on and off 5 times and it should disable your DRL. Do the same to re-activate them.
Old 01-31-2005, 07:54 PM
deadeye deadeye is offline
Re: 98 Blazer..How to turn off Day Time Running Lights?
I didn't see THAT in the owners manual anywhere! Guess that'll work on a 99 too?
Old 01-31-2005, 08:06 PM
toenailclippers toenailclippers is offline
Send a message via AIM to toenailclippers
BEWARE!!! I have a 98LT and that dome override crap didnt work. you need a resistor in place of the little senso on the right speaker grille on the dash if that dome-thingy dont work
Old 01-31-2005, 08:23 PM
blazee's Avatar
blazee blazee is offline
Problem?
There is a thread in the S-10 Forum about disabling the DRLs.
When I got my Blazer the DRL and the automatic headlights were already disabled. They did it differently than the s-10 thread shows. From what I can tell mine was disabled by simply pulling the DRL diode from the fuse block under the hood.
Old 01-31-2005, 08:42 PM
swalt's Avatar
Re: Re: 98 Blazer..How to turn off Day Time Running Lights?
They don't advertise it in the manual as in some areas of North America it is illegal to disable your DRL. The permanent fix is to do the diode in the right dash speaker grill and bend the pin in the relay under the hood. I have a 2000 LS and pushing the dome overide button 5 times does shut off my lights.
Old 01-31-2005, 08:51 PM
swalt's Avatar
I just read the dome overide button trick is only good on the 2000's and up and limited on certain 98/99 models. This link will help you.
http://www.geocities.com/zq8gmcsonoma/drl.html
Old 01-31-2005, 09:17 PM
you will need a 680 Ohm 1/2 Watt resistor. these can be found at Radio Shack for about 50 cents for a pack of 5.
remove passenger side speaker grill on dash. unplug wire from the light sensor (little ball sticking up from the grill). insert resister into plug, and use a zip tie to strap the plug down to the dash. reinstall grill.
THIS IS WHAT WILL THE MODERATOR GUY TOLD ME...TRY IT IT WORKS
Old 01-31-2005, 09:28 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Yip, that will disable the automatic headlights.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-31-2005, 09:39 PM
thanks guys...but what about when the lights turns on when it gets dark?
Old 01-31-2005, 09:43 PM
BlazerLT's Avatar
AF -Advisor
HELLO! It was just posted!
Old 01-31-2005, 09:47 PM
i thought that both those methods was only for the DRL
Old 01-31-2005, 09:59 PM
2000blazerls's Avatar
2000blazerls 2000blazerls is offline
I need to try this. The dome over ride works on my 2000 BUT once I turn the truck off and then turn it back on I have to do the dome over ride trick again. Thanks for the links and info!
Bye Bye Blazer!
http://www.cardomain.com/ride/2159611
Hello Monte Carlo!
http://www.cardomain.com/ride/2445379
