Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 01-31-2005, 06:20 PM
Mayday0017 Mayday0017 is offline
How do I remove Injectors?
Got my engine swap taken care of and have the new KA w/ only 1,652 miles on it in. (have pics of some of the internals) However 2 of the injectors are bad so I need to put two from my old engine on there. I know I could swap the full fuel rail but this one looks so pretty and new. I just can't get the injectors out of the rail. I have both rails by themself w/ the injectors in them but can't get any of them out. Anyone have any tips or suggestions on how to get these things out w/ out hurting them.
Old 01-31-2005, 06:36 PM
Chuki_breath Chuki_breath is offline
Re: How do I remove Injectors?
it just takes some man power. Iv taken em out and fuel comes flying out with them into my mouth and in my eye. It sucked. Of course mine was still hooked up to the engine.
Old 01-31-2005, 10:46 PM
anyone else have any tricks? there isn't anything to pry on or really grab onto w/ pliers and I don't want to damage them due to the fact I am taking them out of one fuel rail and putting them into another I"m just looking for any advise there has to be an easier way
Old 02-01-2005, 01:04 AM
TatII TatII is offline
get a towel and put it over the top of the injector. then use a vice grip and very very gentlely twist and tug.
don't forget to grease up the o-rings on the new injectors with vasaline or oil becuase those o-ring will ripe ( which would cause leaks and rich running conditions ) if you don't.
303whp stock internal KA-T
94 Acura NSX
Best E.T. 13.559
Best Trap speed 107.62 mph
Old 02-01-2005, 02:00 AM
AWDSR20 AWDSR20 is offline
Send a message via AIM to AWDSR20 Send a message via MSN to AWDSR20
http://www.zeroyon.com/pics/installs.../550Z32-1.html
check it out, its for the SR but it migth help, it gives hints on how to remove the injectrz...
"A good driver is measured not by his lap times, but by the amount of time he spend trying to make sense of his car"
E.K.
Old 02-01-2005, 04:30 PM
Anyone here ever removed injectors before? I mean there has to be someone who knows how to do it other then the post about using a hammer, cause that doesn't fix the problem of not wanting to damage them now does it?
Old 02-01-2005, 04:35 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Tat has removed and installed injectors I'm sure.
Chuki, you relieved fuel pressure didn't you? Yea, fuel in your face does suck.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 02-01-2005, 10:21 PM
no i just ripped the bastard out lol. Yea i use the towel and vice grip method. I mean i learned after the first time to close eyes and mouth then continue tugging.
Old 02-01-2005, 11:57 PM
wow i've never had to remove the whole fuel rail before. anyways if you want to relieve the pressure, what i did was access my fuel pump ( on the hump inbetween the back seat, and trunk space )and pull out both connectors goin to it, then just run the car till it stalls out.
then just be really careful with a towel, and a wrench of a vice gripe and pull and twist very very carefully so you don't ruin the top of the injectors. however using hte hammer seems to be another option too.
94 Acura NSX
Best E.T. 13.559
Old 02-02-2005, 01:26 PM
use the hammer just don't hammer away use commen sence...
E.K.
Old 02-02-2005, 04:56 PM
240SX Guy
Or just pull the fuse.lol
-Cory
12.6@122mph
Old 02-02-2005, 08:42 PM
D-Bo's Avatar
D-Bo D-Bo is offline
nissanfanatic i don't think the fuse will relieve the pressure.. even with the car off, the pressure will still stay for quite a while.. if your car hasn't been running for a while (2 weeks minimum) then you'll be fine, it'll dribble out but at least not spray.. if it HAS been running then do what tat suggested.. make sure you have lots of cloth around.. it could get messy even with lowered pressure..
Originally Posted by iVteC_PoWeR
to me when i really look at it hondas just too expensive and theres not much power even after you spend loads of money...
http://www.cardomain.com/id/dbo240
***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE***
Old 02-02-2005, 08:44 PM
D-Bo's Avatar
wait a minute... i'm terribly sorry, i'm on those drugs alexious gave me.. i didn't know you meant pulling the fuse to the fuel pump while the car was running, i thought you meant something else, that makes absolutely no sense at all..
Old 02-03-2005, 01:38 AM
when i pulled the fuse out for the pump, the car didn't want to stall. it was really really weird.
94 Acura NSX
Best E.T. 13.559
Old 02-03-2005, 01:02 PM
240SX Guy
Tats car is possessed.
-Cory
12.6@122mph
