Power/ Economy Switch
Ok I am trying to figure exactly why the switch for economy to power (located near the shifter) is even in the car. I turn it to power on my SL ATX and it has no gain what SO ever. What is the fastest way to make these things go? Im thinkin Overdrive off and manually shifting.
Re: Power/ Economy Switch
As far as the fastest way, only thing overdrive will help you do is if you are racing from a roll, pulling it out of overdrive will go ahead and downshift you so you dont have as bad of a delay (if you dont have a shift kit installed). From a stop, just leave it in drive, put it in power mode, push the brake in, hit the accelerator, and let off the brake after your converter has loaded up.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition 1994 Mitsubishi 3000GT SL-TT Automatic - Black 3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods 1994 Mitsubishi 3000GT VR-4 - Black Intake & Boost Controller so far 2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods |
Also in PWR mine seems to have a better throttle response. like in ECO u can put it half way to the floor and it still wont get up. As far as manual shifting it pretty much sucks. it will shift probably 3 seconds after u have put it into the next gear... at least mine does.
when im goin at like 25 or so and punch it it wont go into first so its really slow from there when the power is on itll go to first and go pretty decent
i have noticed in my car that its not only the shift points but the car also shifts to a lower gear rather than trying to torq its way up to better rpm's in the power mode
Re: Re: Power/ Economy Switch
I just recently smoked some cavalier on the interstate, i got up to 135 and couldnt see him in my mirror anymore, it was a very funny race. Oh and I about lost my moonroof, very scary, it was just flopping up and down cuz i have a broken hinge on the drivers side.
where can u get this shift kit?? and what all does it do.
00blackzx3.. so u beat a cavalier? try racing one from a stop. ive had one behind me b4 at a light and floored it, next theing i know he jumps in the lane to the left of me an walks past me : \ no way that thing was stock tho.. drove home kinda confused that day...
its called a Translab TL-175, you can get it from importperformancetranmissions.com
It makes your transmission shift very quick, much quicker than a manual can, and it also takes care of the delay of downshifting when you mash the pedal to the floor.
how exactly does it work? and is it hard to install?
yes i am very intersted in this as well... whats installation like...
it basically works by installing stiffer springs and increasing the pressure inside your valve body.
As far as installation, its not an easy installation, you would need some knowledge of how to do it, but its nothing impossible. I did mine, works beautifully, and all i needed was a set of 1/4 inch socketwrench set, the kit, and silicon gasketmaker. Remember, you will be opening up the transmission, pulling out the valve body, tear it down completely, and put it all back together.
tear it down completely? nevermind, i think ill wait on that one
.... is there a site anywhere that shows the install and pics?so the only thing in the kit is stiffer springs?
