Old 01-31-2005, 05:04 PM
billbertreed billbertreed is offline
PCV filter/hose help NEEDED
89lx5sp. Is the PCV valve in the PCV hose? How do you get the hose off of the PCV valve? Hard pulling, lubrication? Does the PCV valve screw out then? I've seen the diagram. So many questions!!
Old 02-02-2005, 05:19 PM
Shaguar47's Avatar
Shaguar47 Shaguar47 is offline
Send a message via AIM to Shaguar47
Re: PCV filter/hose help NEEDED
It depends on what engine you have too. But usually on the d15's it's screwed in the intake manifold right below the big black air box that says DPFI on it. Really all you do is push down the clamps on the hose, pull the hose off, then unscrew the pcv it self from the intake manifold. Replace it with a new one in the opposite order. Not hard at all.
Also if you have an si with the d16 in it, it just pulls right out rather than screwing out.
1990 Black Geo Storm - RIP -
1990 Blu metallic Std Hatch
1999 Milano Red Ex Coupe
Current -- Ex to Si. It's Overdone, but who gives a crap. I don't!
