Old 01-31-2005, 02:51 PM
kallenbach_05 kallenbach_05 is offline
Fram Air Hog Air Filters
what are your views on this air filter. I am wanting to get one for my 97 SE, but not sure if it will actually do what they say it should. Any input will be helpful.
Old 01-31-2005, 03:56 PM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Re: Fram Air Hog Air Filters
If you're going with a different drop-in filter, go with a K&N filter. My advice would just be to go with a cold air intake or warm air intake setup, but if you're still doing stock filters go with a K&N.
Old 01-31-2005, 05:46 PM
Madcat455 Madcat455 is offline
I wouldn't waste your money... Your not going to see any noticeable performance gain unless your air filter is really clogged (but then a normal new one would feel that much better too).
96-98 Grand am's are cold air setups... the inlet for the air box is right behind the Left headlight, out of the engine compartment.... So use your judgment there.
Old 01-31-2005, 09:25 PM
Forkliftguy's Avatar
Forkliftguy Forkliftguy is offline
Almost every single car on the road uses a cold air setup. It has been that way for decades. An aftermarket cold air systems gives you a larger snorkel and eliminates the air box giving you a lot less restriction thus improving power.
Ridenour's got a good point going with the K&N filter if your staying with the stock cold air system, I use one. It's true the gain is minimal at best. I've noticed a bit better top end performance, the engine reacts a bit quicker to full on throttle from cruising.
MECP Level 1 Installer
Mobile Dynamics Corp. Certified Installer
Clifford Electronics Cetified Mobile Security Installer
Electrician in training
'01 GA SE, Stock....for now.
SudburyGrandz
Old 01-31-2005, 10:35 PM
well i went ahead and bought one and I love it. i get a lot better gas mileage now then i did with the old paper air filters. i can definitely feel a difference in the acceleration and overall performance.
