Go Back   Automotive Forums Car Chat > Hyundai > General Discussion
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 01-31-2005, 02:25 PM
twospirits twospirits is offline
Ex-Janitor of AF
60,000 Mile Service
The following is the items performed on the Hyundai 60,000 Mile Factory Service schedule. It is taken directly from the Original Hyundai Factory Service Schedule.
To return to the full Service Schedule thread, click here.
60,000 Mile Service
Hyundai Factory Recommended Service
  • Change engine oil
  • Install Genuine Hyundai oil filter
  • Inspect fuel lines, fuel hoses and connections
  • Inspect insulator of fuel injector (2.0 SULEV Elantra. Note: If removing injector, insulator and O-ring should be changed).
  • Inspect Vapor hose and fuel filler cap
  • Inspect crankcase ventilation hose (Santa Fe only)
  • Replace air cleaner filter
  • Replace spark plugs (platinum coated)
  • Inspect valve clearance (Elantra and Tiburon only)
  • Inspect drive belts (Elantra, Tiburon, XG350, 2.7 V6 Sonata, and 2.4 DOHC/2.7 V6/3.5 V6 Santa Fe)
  • Replace drive belts (2.4 DOHC Sonata)
  • Replace engine coolant
  • Replace timing belt (Recommended for California, not required)
  • Inspect manual transaxle oil
  • Inspect automatic transaxle fluid
  • Inspect brake fluid
  • Inspect brake hoses and lines
  • Inspect rear brake drums, linings and parking brake
  • Inspect brake pads, calipers and rotors
  • Inspect exhaust pipe and muffler
  • Inspect suspension mounting bolts
  • Inspect steering gearbox, linkage and boots/lower arm ball joints
  • Inspect upper arm ball joint (Sonata and XG350 only)
  • Inspect power steering pump and hoses
  • Inspect power steering belt (Elantra and Tiburon)
  • Inspect driveshafts and boots
  • Inspect air conditioning and refrigerant
Premium Dealer Recommended Services**
  • Rotate tires
  • Inspect belts and hoses
  • Replace wiper blades
** = These are not part of the service and will incur additional costs.
TS
The more the members are involved in the process of development, the better we will be as a community of Automobile enthusiasts. Have a suggestion to make the community better, let us know.
Remember, the "No" is always there, you are just looking for the "Yes"
Members please read: Guidelines
Closed Thread
