Go Back   Automotive Forums Car Chat > Hyundai > General Discussion
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 01-31-2005, 01:46 PM
twospirits twospirits is offline
Ex-Janitor of AF
30,000 Mile Service
The following is the items performed on the Hyundai 30,000 Mile Factory Service schedule. It is taken directly from the Original Hyundai Factory Service Schedule.
To return to the full Service Schedule thread, click here.
30,000 Mile Service
Hyundai Factory Recommended Service
  • Change engine oil
  • Install Genuine Hyundai oil filter
  • Inspect fuel lines, fuel hoses and connections
  • Inspect insulator of fuel injector (2.0 SULEV Elantra. Note: If removing injector, insulator and O-ring should be changed).
  • Inspect Vapor hose and fule filler cap
  • Replace air cleaner filter
  • Inspect drive belts
  • Replace engine coolant
  • Inspect timing belt
  • Inspect manual transaxle oil
  • Inspect automatic transaxle fluid
  • Inspect brake fluid
  • Inspect brake hoses and lines
  • Inspect rear brake drums, linings and parking brake
  • Inspect exhaust pipe and muffler
  • Inspect suspension mounting bolts
  • Inspect steering gearbox, linkage and boots/lower arm ball joints
  • Inspect power steering pump and hoses
  • Inspect power steering belt (Elantra and Tiburon)
  • Inspect driveshafts and boots
  • Inspect air conditioning and refrigerant
Here is why they do it:
Your Hyundai is now due for its first major service. All of the basic services have been performed. Now the tehcnician use specialized equipment to more closely inspect your vehicle and make certain that all the mechanical, electronic and computer devices are working properly. At this time, they also address your vehicle's heating and cooling system. Over time, your vehicle's engine coolant can becoame contaminated, losing its ability to protect your engine during extreme fluctuations in temperature. The coolant also will lose its ability to protect the metal components in your vehicle's engine from rust and corrosion, causing premature engine and gasket failure. Expensive repairs could result from the lack of this required mainenance.
Premium Dealer Recommended Services**
  • Rotate tires
  • Inspect belts and hoses
  • Replace wiper blades
** = These are not part of the service and will incur additional costs.
TS
The more the members are involved in the process of development, the better we will be as a community of Automobile enthusiasts. Have a suggestion to make the community better, let us know.
Remember, the "No" is always there, you are just looking for the "Yes"
Members please read: Guidelines
Closed Thread
