Old 01-31-2005, 11:14 AM
Tech_n's Avatar
Tech_n Tech_n is offline
New Engine
I was thinking about buying a new engine for my 3.8 Pontiac Grand Prix,
but I did not know whether or not if I should buy it from the dealership. Can someone give me advice on that. Also, if I have a 3.8, non superscharge engine, could I put the supercharge in my car.
Old 01-31-2005, 11:17 AM
BIG-L's Avatar
BIG-L BIG-L is offline
Yes, if you want to change the wire harness and PCM.
ClubGP Member 6530
Since 2001
Old 01-31-2005, 01:21 PM
Tech_n's Avatar
Re: New Engine
so you have to change the wire harness and the PCM, damn..
So what about getting a new engine, what would you do, would you go to the dealer or get it rebuilt. I know at the dealer I would be able to get another 200 thousand miles of it
Old 01-31-2005, 01:48 PM
BIG-L's Avatar
Id get a an AC-Delco remanufactured long block GM part # 12465148,it come's with a 3yr/36,000 mile warranty.
~Larry~
ClubGP Member 6530
Since 2001
Old 02-01-2005, 05:30 AM
Tech_n's Avatar
Re: New Engine
Thanx, where did you get you pipes from and how much did they run you. Also, what is the name of those pipes/mufflers.
On the other hand is that a different type of engine or is that the same that come with the car. Also, if that is different, would I have to add stuff to it.
Old 02-01-2005, 08:07 AM
BIG-L's Avatar
Ive got a custom exhaust,3in stainless steel downpipe with a carsound/magnaflow cat, u-bend delete 3in to y-pipe to dynomax super turbos and the tips are from www.fastoys.net.
I looked up a 98 GT 3800,not sure what year your's is.The part # I listed is for a 97/99 long block.Only parts to swap out on a long block is, PS pump,alternator and throttle body,add some new plugs.
~Larry~
ClubGP Member 6530
Since 2001
Old 02-01-2005, 10:10 AM
Ripn12s's Avatar
Ripn12s Ripn12s is offline
Send a message via AIM to Ripn12s
Re: New Engine
I'd call up Ed Morad get a used motor and take the money saved and throw it into a turbo setup for the car.
