Old 01-31-2005, 08:22 AM
92VR4Red's Avatar
92VR4Red 92VR4Red is offline
high boost
im running the stock turbos but some how at 1.5+ KpA (around 22 pounds+) how is this possible. i have a hks BOV but that shouldn't have any effect... i have a aftermakret electronic boost guage so its not off... its a greddy boost guage not some cheap offbrand... but i know its not good to run such high of boost. and i did not turn up the boost or gain on the boost guage infact i have the limiter in effect and still it over boosts... any idea?
Upgrades... To many to list...
Old 01-31-2005, 08:25 AM
G35turbo G35turbo is offline
Re: high boost
I dont now what it could be, but i would suggest to not drive the car till you get it fixed. Because i think 1.5+KpA is toooo much for the little 9b turbo!!!!
Old 01-31-2005, 01:25 PM
Igovert500's Avatar
blue + red light magnet
Re: high boost
If you mean you have your Profec set lower, but that your gauge shows 22psi, then a serious boost leak would be my first guess. What are your Profec settings? Also, I assume you mean that it peaks at 22psi, what is it showing at redline?
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 01-31-2005, 05:53 PM
92VR4Red's Avatar
Re: high boost
no leak... cheacked already... i mean hours of checking... i have one peak at 29 lbs but only once... car runs great... i only over boost when i give it over 50% throttle... setinsg are 0% boost, 15% gain, limiter set at 50% starting at 12lbs...
Old 01-31-2005, 06:04 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
Re: high boost
what happens when you turn off the profec? what are you running then?
Old 01-31-2005, 06:06 PM
92VR4Red's Avatar
Re: high boost
dont know... ill try and see what the results are.
Old 01-31-2005, 06:41 PM
Hotshot8792 Hotshot8792 is offline
Re: Re: high boost
are you using the boost controller as your boost gauge? I'd check it, the stock turbo can't even spike 22lbs into our engines. Gain needs to be set at 5-7%, i have mine at 5. Check your connections and make sure nothing is messed up. Also, i'd assume your on stock injectors by looking at your list. If so, you'd hit fuel cut at around 15 anyways.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 01-31-2005, 07:34 PM
92VR4Red's Avatar
Re: high boost
yes im very sure if you read my fisrt post i said i have a greddy electronic boost guage .
here it is when boost guage is off...
1 st gear - .9 KpA at 6000rpm
2 nd gear - 1.1 KpA at 6000rpm
3 rd gear - 1.5 KpA at 5000rpm
4 th gear - 1.8 KpA at 4000rpm
5th gear - (did not try too low rpm)
Old 01-31-2005, 07:37 PM
92VR4Red's Avatar
Re: high boost
yes stock injectors. ive been trying to find 450cc injectors in sets of 6... ive heard that im suposed to fuel cut at 15... but for some reason im not... trust me ive checked everything to make sure im correct... every connection on all elcetronics and check for leaks in intercooler lines...
Old 01-31-2005, 10:01 PM
Re: Re: high boost
something seems very fishy about that. Maybe your boost controller is defective.
Old 02-01-2005, 08:26 AM
92VR4Red's Avatar
Re: high boost
woops typo on msg lol. when boost "controller" is off
not guage lol...
Old 02-01-2005, 08:30 AM
92VR4Red's Avatar
Re: high boost
iono mabey... but everything is reading high boost...
the stock guage hides the bar... the boost controller has a guage on it and its reading about the same as the boost guage... but still shouldnt the computer limit that even if the boost controller is defective... plus it was doing it with the boost controller off too...
can anyone tell me what they set their Profect on stock turbos? because i have a big front mount comeing in the mail and that will only up the boost more... (no flexing hoses and cooler air).
mabey i should gewt bigger injectors to help keep up with the air...
Old 02-01-2005, 08:33 AM
92VR4Red's Avatar
Re: high boost
or... i could get a external wastegate and set it to start releasing boost at 15lbs... but then those are expensive :S
Old 02-01-2005, 11:35 AM
BB1970's Avatar
BB1970 BB1970 is offline
Re: high boost
i had this on a completly different car once and found that the vaccuum pipes were not connected in the correct place, hence the stock electronic boost solenoid was actually being by-passed.
To me,this is the only way you could possibly get a higher boost setting past 15psi before you will fuel cut,but dont hold me to it, long shot i know, but id check your vaccuum lines, especially if you have had the stock pipes disconnected or played with them at some point i would seriously check them.
you can find a diagram of where they all go in stealth316 website i think.
hope this helps and would love to know the outcome.
BB
1993 Mitsubishi GTO Twin Turbo (RHD) NOW SOLD!!!
9b turbos with manual boost valve mod set @14psi
turbo xs type h-rfl blow off valve
blitz dome filter
sachs clutch
completely de-catted
fuel pump voltage rewire mod
ebc redstuff front brake pads
greddy fully automatic turbo timer
now drives a sensible family sedan. A 340hp 1997 mitsubishi evolution IV
