Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 01-31-2005, 12:39 AM
SMarquez SMarquez is offline
No Start after Cleaning
88 camry 3sfe. I sprayed throttle body cleaner in the TB while the car was not running. I put the air tube back on and could not get it to start. It will barely fire with starter fluid but will not run. What did I do?
I'm going to let it sit over night in case something got wet that should not have. Any suggestions?
Old 01-31-2005, 06:29 AM
jsinton jsinton is offline
Re: No Start after Cleaning
What's a "TB"? Turbo? Throttle body? You are supposed to spray that stuff with the engine running, aren't you? Just let it dry out, it should be ok.
Old 02-15-2005, 04:08 PM
sixesnsevens sixesnsevens is offline
I'd also reccommend taking out the spark plugs to hasten the drying. Re install them and see what you get.
