Old 01-30-2005, 10:29 PM
IntegraBoy405 IntegraBoy405 is offline
Banned
Wiring Basics
Does anyone know any good websites on different ways to wire from amp to sub(s). I want to know the different ways to get different impedances. Also, does a dual 4 ohm vc equal 8 ohms? what is the most smallest impedance you can get two 4 ohm DVC's down to... 8? confusing.
Old 01-30-2005, 11:52 PM
95tahoe4x4 95tahoe4x4 is offline
JBL.com or JLaudio.com - go to the product support and to the wiring diagram sections - it does not matter if you do not have JBL or JL, all subs wire the same.
There are two basics to consider, parrallel or series, one will yeild a higher ohm rating than the other. If you do not have an amp that is 2 ohm stable (meaning it wont shut down) then you do not need to be concerned with the series wiring.
dual voice coil (DVC) will yield a different ohm rating at the amp than a single voice coil (SVC)
It all starts at the amp, a good amp will drive a medium quality speaker wild, but a high quality speaker with a cheap amp will crap out and you will think that brand of speaker sucks, when it is your amp.
Ohm = resistance, which changes all the time, but the number is there for a starting point,
2 Ohms at the amp make it run hard (puts out more watts) but extremely hot (an amp that is not 2 ohm stable will shut down very quickly) 4 or 8 Ohms make the amp not put out as much, but is much safer for the amp, MOST AMPS ARE NOT 2 OHM STABLE - ESPECIALLY THE CHEAP ONES THAT CLAIM TO PUT OUT 3,000 KZILLION WATTS o.k. I exaggerated but hopefully you get the idea.
it is easier to look at the pictures than explain, good luck.
Kt - email me if you have more questions, I have installed about 35 compete systems (deck, speakers, crossovers, amps dvd, etc.)
Old 01-31-2005, 01:53 AM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Wiring Basics
a dual 4 in parallel will give you 2ohm, a dual 4 in series will give you 8ohm
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 01-31-2005, 11:35 AM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
Re: Wiring Basics
"ohm rating".....hmmmm Haven't heard this one yet.... my favorite so far is ohmage...... PEOPLE IT'S CALLED IMPEDANCE! lmao...... dude w/ the "ohmage" q..... look at it this way..... if you wire in parallel (+to+ -to-)it will be half the impedance of ONE coil..... if you wire series (amp+ to +on coile one -on coil one to +coil 2 -coil2 to -amp..... it will be the 2 VC's added) For example in SERIES dual2 would be 4 Dual 3 would be 6 Dual 4 would be 8 dual 8 would be 16......in paralell d2 would be 1 d3 would be 1.5 d4=2 d8=4....... ok ur good to go n e more q's jusss ask.
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
Old 09-24-2005, 04:32 PM
rowdyacehole101 rowdyacehole101 is offline
Send a message via AIM to rowdyacehole101
how do i wire 1 15" kicker to keep it at 4 ohms its kicker cvr dvc for max power
i need help on wiring a kicker comp 15" dual voice coil speaker by itself max power at 4 ohms
