Old 01-30-2005, 11:26 PM
chembrad chembrad is offline
Just bought a '94 Metro
168k miles, 1.0L. Only cost me $350. Interior and exterior is ok.
Problem is that the pressure plate must be messed up as it doesn't engage much.
Anyway, this will be my first clutch job. Any special tools I need to get for this job? Any tips you guys can help me with?
'05 Dodge Grand Caravan 105k miles
'94 Geo Metro 1.0L 5spd 185k miles... at least I can fix it!
Old 01-31-2005, 12:23 PM
geozukigti geozukigti is offline
Well, it's no different than any other FWD clutch. Remove starter, drain trans, remove drivers side CV axle, unbolt the trans from the engine and motor mount and the inspection plate, unbolt shift linkage from trans, take clutch cable off the trans, unplug reverse light switch , pull the trans off. unbolt the clutch from the flywheel, and the flywheel machined. Install new clutch, and assemble. USE TORQUE SPECS FOR THE BOLTS FROM THE MANUAL! Or you'll run into some major issues like bolts vibrating loose, or breaking heads off bolts when you install them. Shouldn't take more than a few hours.
Old 01-31-2005, 12:29 PM
Oh, and tools... Just a basic ratchet set, ball joint seperator, torque wrench, breaker bar, 30mm axle nut socket, and clutch alignment tool(which should come with the new clutch). If I missed anything, sorry
Old 01-31-2005, 04:48 PM
Do you change the clutch with the stick in neutral? Stupid question but I have to ask.
Old 01-31-2005, 04:50 PM
So where is a good place to buy a good clutch? Just local autoparts store?
Old 01-31-2005, 04:53 PM
Another stupid question:
What parts will I need to purchase to replace the clutch?
Old 01-31-2005, 05:17 PM
Re: Just bought a '94 Metro
I found a clutch kit at autozone that includes the pressure plate, clutch disk, throwout bearing, and the alignment tool, with a lifetime warranty
for only $100. SOLD! That sounded like a good deal to me.
What is a good price for machining the flywheel?
Old 01-31-2005, 05:24 PM
Re: Re: Just bought a '94 Metro
One place wanted $35 and the other one $40.
But I can get a brand new flywheel for $50!
Old 02-01-2005, 10:10 AM
$50 for a NEW flywheel? rock on, get it! It'll cost $30-$40 to have yours machined. Just make sure it has the alignment pegs in the flywheel.
Old 02-01-2005, 04:37 PM
Thanks man!
Yeah 49.99 at Kragen Autoparts.
Old 02-03-2005, 03:25 PM
But I just found out that I have to pay $101 to DMV to begin the process to change the title over to me!
Sooooo, $350 for the car, $101 for DMV, ~$200 for the clutch job. THEN I should have a decent beater car!
Old 02-08-2005, 02:38 PM
So do you have the stick in neutral when you do this job? Or doesn't it matter? Dumb folks want to know...
Old 02-08-2005, 05:21 PM
You should have it in 6th gear.....
The gear Doesn't matter. You have to have to shift linkage taken off anyways.
Old 02-08-2005, 07:59 PM
mik13usa's Avatar
mik13usa mik13usa is offline
That was evil Alan!
Old 02-09-2005, 05:33 PM
Well at least he gave me the answer. I don't have any prob with some good fun.
The prob is when peeps joke about n00bs and then don't help them.
Besides, I'm not a real n00b anyway. Just to clutches, this being my first. I'm sure I will muddle through it.
