Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 01-30-2005, 09:22 PM
lenalogan lenalogan is offline
98 dodge 1500 5.8 L stalling when hot
the thermostat stopped working and at the same time the car is hard to restart after it has been running can only put it in gear if I have my foot on the gas otherwise it will die IT runs great once you get it going.
whats wrong?
Old 01-31-2005, 07:57 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: 98 dodge 1500 5.8 L stalling when hot
Does it start ok when cold? How many miles on it?
Sounds like it may be the throttle position sensor.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 01-31-2005, 09:57 AM
Originally Posted by lenalogan
Yes it start with no problem when it is cold.
as soon as I shut it of when warm and try to recrank it it dies and I have to put my foot on the gas and then put it in to gear. it will run just fine after that It does not stall out only when starting it up. my thermostate does not move att all as well and these to problems happend at the same time.
thanks a million.
So...only when warm, and only when starting up? No problems any other time. That's very odd indeed.
I'd get the thermostat repaired first, then see what happens. It may be that since the thermostat isn't working properly, a sensor somewhere in the engine (when warm) is sending the wrong message at startup, then once the water circulates for a moment, it clears up.
