Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 01-30-2005, 09:14 PM
94CIVICDXTuner 94CIVICDXTuner is offline
Send a message via AIM to 94CIVICDXTuner
Cool A Chip?
I read about some kind of VTEC chip you can install into your motor.
What is it, what does it do, and how much does it cost?
Bout to bounce back with a body kit, a paint job, a spoiler, a lowering kit, a camber kit, and some 17's........Due by September 05'.
Old 01-30-2005, 09:40 PM
tencent's Avatar
tencent tencent is offline
Send a message via AIM to tencent
Re: A Chip?
from what I understand a v-tec chip lets you initiate the v-tec sooner (lower rpms) and I think I've seen them for like 100 bucks online. Just splice it into the v-tec solenoid wire and make sure you wire an on-off switch for it because you don't want that on all the time.
Powered By Rice
Old 01-30-2005, 10:01 PM
Doubletap Doubletap is offline
Send a message via AIM to Doubletap Send a message via Yahoo to Doubletap
Re: A Chip?
From what I have read it is generally not a good idea to lower the vtec engangement signficantly. At lower rpm you canot effectivly make use of the additional fuel and air anyway it will just put more wear and tear on you motor.
DoubleTap
Old 01-30-2005, 10:10 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: A Chip?
Unless you have aftermarket camshafts and you are on a dyno with a wideband O2 sensor, changing any VTEC or ECU settings is pointless and you will lose power.
