Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 01-30-2005, 06:26 PM
jjmccloud82 jjmccloud82 is offline
do i have a interfarence engine {95.5 3.2 passport}
i have a 95.5 3.2 passport engine is it a interfarence engine
JJ
Old 01-30-2005, 06:58 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: do i have a interfarence engine {95.5 3.2 passport}
nope it is not interf. engine
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 01-30-2005, 07:22 PM
what makes a engine a interference engine or not
JJ
Old 01-30-2005, 09:17 PM
Cat Fuzz Cat Fuzz is offline
On some engines if the the timing belt breaks the valves and pistons will hit each other and cause major damage.
Old 01-30-2005, 10:35 PM
Super 95.5 Rodeo Super 95.5 Rodeo is offline
Send a message via AIM to Super 95.5 Rodeo
So, which engine will cause piston/valve damage.
Brian Creelman
MSgt USAF Reserve, Retired
1995.5 Isuzu Rodeo S 4WD 3.2L V6 247542 miles
2004 Ford F-250 Super Duty Crew 6.0 Diesel
2006 Ford Mustang GT Coupe Tungsten Grey
Old 01-30-2005, 10:46 PM
Isuzu Guy
2.2L GM engine in the Rodeo.
-Ryan
Isuzu Moderator
Car Show Tips
Old 02-01-2005, 11:26 PM
Edn Edn is offline
If you have the 3.2L, it is an interference engine.
Old 02-01-2005, 11:31 PM
Edn Edn is offline
Re: Re: do i have a interfarence engine {95.5 3.2 passport}
An interference engine has that problem because the valves can interfere with piston travel if the timing belt breaks. My problem! I'm hoping there is no damage.
Old 02-02-2005, 12:07 PM
There is alot of literature out there claiming that the 3.2L is an interference engine, but its not true. There are many people on this board with first hand knowledge that it is non-interference. So, no worries!
Old 02-03-2005, 12:33 AM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
Isuzu does state that the 3.2L engine is an interference engine however I have been inside hundreds of these things I have even gone as far as pulling the t-belt off of my own 3.2L and spinning it over with the starter no damage incurred
I have never heard of one of these having a problem with pistons hitting valves
oh and by the way the heads on my Trooper have been machined twice which means the valves are closer to the pistons than yours are
Old 02-03-2005, 01:20 PM
95.5 Rodeo's Avatar
95.5 Rodeo 95.5 Rodeo is offline
Interesting.
Why have the heads on your Trooper been machined?
Were they warped?
Just wondering...
Dale
Old 02-03-2005, 06:44 PM
Re: Re: Re: do i have a interfarence engine {95.5 3.2 passport}
Originally Posted by 95.5 Rodeo
Interesting.
Were they warped?
Just wondering...
Dale
HiPo TROOPER BAY-BEE!!
Old 12-08-2005, 09:15 PM
hside82 hside82 is offline
I beg to differ with you my friend, I have a factory service manual and also an Isuzu Factory Engine tech training manual for the 98+ 3.2 V6. Here is a piece from the book. "The angle of the exhaust seat has also been changed;relocated in the direction of the intake valve,this feature helps increase the clearance in-between the intake and exhaust valves.This feature enables the engine to "Free Wheel" in the event of a timing belt failure. So that is fact that the 98 and on 3.2 L V6 (6VD1-W) is definately non-interference.
Old 12-08-2005, 11:09 PM
directory's Avatar
directory directory is offline
non-interference....
a quick search of the forum with show you that...
99 passport 3.2L v6 DOHC auto-trans 4x4 modified IFS 10 bolt front/ dana 44 4.10 rear
SKYWARN
we be clubbin'
--B
Old 02-05-2006, 08:58 AM
DPDogg DPDogg is offline
Now I am a bit confused - Is my 1995 3.2 built Oct 94 interference or not?
