Old 01-30-2005, 05:38 PM
jackmalone2001 jackmalone2001 is offline
strange issue, indeed
Hi to all, it has been a while but I guess that is good news.
the backstory:
I have a 1994 v6 Camaro involved in a flood, took her apart and replaced a buttload of pieces, put her back together and hit the road.
Two things I have not replaced were the battery and the alternator.
Driving down the highway today, I hit my rear defogger switch and it seemed for a second like my girl wanted to stall. (Of coarse at 75 that is kind of hard.) there were no other electrical componants on at the time. (Other than the engine, and engine management stuff.)
So, my question is:
Is there any way to determine which needs to be replaced, battery or the alternator, in a situation like the one mentioned above.
Thanks for any help or advice you have!
Jack
before:
after:
Old 01-30-2005, 07:39 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: strange issue, indeed
Start the car, run it for like 3 minutes. turn on all the power accesorys and then pull the positive battery terminal. If it stalls. then its the alternator. If it stumbles for a sec then volts come back up or doesn't stumble at all then alternator is fine and maybe you could use a battery. Also welcome back.
John
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 01-30-2005, 08:02 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
Seeing how you didnt replace either one, I'd say replace both anyway
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 01-30-2005, 10:16 PM
Morley Morley is offline
It is never a good idea to remove the battery cables on a computer controlled car while it is running.
FormulaLT1's Avatar
Fight the powwa!!!
who told you that?
Old 01-30-2005, 10:25 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Honestly, I don't think it's the battery or the alternator, if everything was fine until you turned the rear defog on then perhaps your problem lies within that.
Old 02-01-2005, 04:51 PM
Formulalt1--interesting idea, but I have heard it said in this forum NOT to disconnect the battery when the car is running---but you say that if I do this it is the alternator, and NOT the battery? 97camarors posted "replace them both", good idea but if I had that kind of scratch, I wouldn't be begging for help! So, other than removing the positive battery cable while the car is running, there is no way to determine if the battery or the alternator is defective?
before:
after:
Old 02-01-2005, 04:56 PM
FormulaLT1's Avatar
Fight the powwa!!!
Contrary to what some guy told some guy. Your not going to short anything out or blow up your car from pulling the positive battery terminal. It is infact a testing method done in almost every dealership in the world. Plus if you have a healthy charging system your car won't even blink. If it stalls your car alternator isn't giving enough juice to keep your car running let alone charge your battery like it should be doing.
John
Old 02-01-2005, 08:19 PM
Xenostalgia's Avatar
Xenostalgia Xenostalgia is offline
Send a message via AIM to Xenostalgia
Dude...whoa...
1: If your car turned into a submarine as the pictures state you should check all the wiring for any rust/corrosion and or breaks.
2: If there is any pulley connected to the engine for that maybe you should check that too.
I dunno if theri s a pully. Otherwise take it into a mechanic and ask wtf.
Originally Posted by 97CamaroRS
You know he's cruisin in the GN above us - RIP, Andy
Be Warned....
Originally Posted by twospirits
what your name really means...
XENO...
Xtreme
Emotional
Neurotic
Ominous
www.Xenostalgia.com Exit your Reality || 97 Acura Integra GS 2DR
Old 02-02-2005, 02:07 AM
Re: Re: strange issue, indeed
Originally Posted by FormulaLT1
who told you that?
Ummm, lets see..GM, My owners manual, every mechanic I've talked to...pretty much everyone.
Also, if you do pull the battery cable the car will shutoff no matter if the alt/battery are good, bad or whatever. You have just removed power to the ECM, which is tapped off the positive cable on a pigtail, no ECM= no injectors, no sensors & no workie.
The old pull the battery cable tricked worked great, until the advent of F/I.
Old 02-02-2005, 01:31 PM
seems like I started quite the debate! Sorry! Xeno mentions a pully, I am not clear on what he's talking about. Also says to check the wiring, good advice. Thanks guys--
before:
after:
Old 02-02-2005, 01:48 PM
FormulaLT1's Avatar
Fight the powwa!!!
Re: Re: Re: strange issue, indeed
Originally Posted by Morley
Also, if you do pull the battery cable the car will shutoff no matter if the alt/battery are good, bad or whatever. You have just removed power to the ECM, which is tapped off the positive cable on a pigtail, no ECM= no injectors, no sensors & no workie..
Dude I have tested this method on my FUEL INJECTED car plenty of times and if your going to correct me with bogus info again. I would prefer you not reply at all. The alternator is what charges your coil, your power accesory's and your PCM. Follow your positive power terminal. If you disconnect the Ground then yes the car would die or stall but the postive terminal has a 3 way way wire split. One goes to the battery, one to the alternator and the other is connect ot a terminal that runs to the PCM amongst a few. Also youn must be reading something incorrectly cause my uncle had worked at a dealer for about 20 years before he bought his own shop and he is a Automotive electrical engineer specialist and he is the one who taught me how to test this way. So if he is wrong then the world makes a little less sense to me.
Old 02-02-2005, 03:42 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
y dont you just do it the easy way and take your car down to advace auto and have them test everything for free with their diagnostic tool...
*Better power-to-weight ratio than a C6 corvette*
Old 02-03-2005, 03:14 PM
Ja... Uh pulleys the lil spinner discs that turn the belts on the front of the crank on the front of your engine. e.e that kinda thing... uh yah.... (not good with technical details)
Be Warned....
XENO...
Xtreme
Emotional
Neurotic
Ominous
Old 02-03-2005, 07:59 PM
Re: Re: Re: Re: strange issue, indeed
Dude
First off, I am not a "dude".
secondly, trace the wire coming off the battery that has a nice little fuse in it, that powers the ECM and fuel pump. pull that cable and it all shuts down, period. I have been working on cars for 30+ years now and know them pretty well, I have been working on TPI's for the entire 20 years they have been around and know how they do and don't work.
You don't like my advice..don't take it. Bogus? Hardly.
Oh, and another reason not to remove the battery cable from a running car is that the ECM's are VERY intolerant of voltage spikes and have no way to protect themselves. But hey, they only cost $110+, so take a chance
