Old 01-30-2005, 04:47 PM
mkazyss mkazyss is offline
Fog light replacement
I need to replace my driver side fog light, but am not sure how to get the light out of the socket.
Any help would be appreciate.
Kaz
Old 01-30-2005, 05:10 PM
Ripn12s's Avatar
Ripn12s Ripn12s is offline
Send a message via AIM to Ripn12s
Re: Fog light replacement
Reach under the car you'll feel the 2 plastic wingnuts that hold the light in. Remove wingnuts, disconnect the wires and push out through the front.
Old 01-30-2005, 05:36 PM
stlwagon stlwagon is offline
Are you talking about removing the bulb or the entire lens assembly? Bulb removal is simple. Grasp the base of the socket and turn to the left. It should then pull right out. If it's been in there for awhile, it may take some force due to dirt, salt etc. When replacing, be sure not to touch the glass part of the bulb. Oils in your skin will shorten the life significantly.
Old 01-30-2005, 05:45 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Yep, Wagon's right.
But if you want lights you can see by, gey a hold of Big-L. He has the set up.
Kaz
