Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 01-30-2005, 05:03 PM
golee1 golee1 is offline
1977 Thunderbird transmission question
My '77 Thunderbird's transmission is slipping, so of course I want to get it fixed as soonas possible. I've got a little problem though...the guy I usually go to for Transmission work doesn't work on FMX transmissions. So my question is...did all '77 Thunderbirds have FMX transmissions,and if not, how can I tell if mine has one or not.
thanks in advance,
Patrick
Old 01-30-2005, 07:34 PM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
Re: 1977 Thunderbird transmission question
Well, it could've been a C4 or a C6, also. Still poking aroung to see if I can find the difference.
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
Old 01-30-2005, 08:15 PM
Well, about the only thing I found when I searched for "FMX vs C6" is that they are hard to find parts for, they are inferior to a C4 or C6, and they typically were found bolted to a 351. Oh, and they need a different flywheel/flexplate than a C6. So, unless you want to keep the FMX for sentimental purposes, drop in a C6 and be happy.
Old 03-18-2005, 03:09 PM
tbirdtess tbirdtess is offline
thanks in advance,
Patrick
To tell the difference between the C4,C6 & FMX
C4 has A bolt on Bell housing from inside the Bell housing
C6 Has A one piece housing, from Block to tail
FMX has A bolt on housing from outside the Bell Housing(4 external Bolts)
The C4 & FMX take less House Power to run than the C6 so unless you modified your engine greatly stay with the FMX or go with the C4.
I currently run A FMX in my 1990 T-bird Stock Car. The FMX has a cast iron case. Is heavier than the C4. But the FMX is stronger.
Good luck.
