Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 01-30-2005, 03:04 PM
neogeo124 neogeo124 is offline
hey newbie auto/manual swap q
hi everyone, I'm new here and I was looking at a fiero 2m6 for a next car, it has a auto tranny..... how hard would a manual swap be?.
I was thinking I would just need
column
shifter
shifter cables
brake/clutch pedal cluster
clutch line
and lastly a manual tranny..... is that everything? is it worth it?, should I go for the getrag 5?
thanks, very much
Old 01-30-2005, 08:30 PM
FierceGT's Avatar
FierceGT FierceGT is offline
Send a message via MSN to FierceGT
Re: hey newbie auto/manual swap q
You shouldn't need a new column, but the main wire harness is not the same. The position of the reverse lighting switch is not the same. The clutch start enable switch is not the same as the automatic Park/Neutral switch. There are subtle differences in them, and to change it out requires almost complete disassembly of the interior and disconnecting some wires from the engine. If you are really wanting a manual transmission, you would be much better off to continue your search for what you want.
Old 01-30-2005, 08:36 PM
Re: Re: hey newbie auto/manual swap q
ok but I meant the water fall or whatever you want to call it not the steering column. ok yea I know of a fiero gt around here that I might be able to persuade the owner to sell
Old 01-30-2005, 08:50 PM
fierangero's Avatar
fierangero fierangero is offline
Send a message via AIM to fierangero Send a message via MSN to fierangero Send a message via Yahoo to fierangero
im willing to do the manual swap, since im swapping the engine and the wiring harness anyway
Rest In Peace, Rich Hall
my baby: 1986 Fiero GT: v6, automatic, 2.8L, 2.02/1.60 heads, Crane Performance Cam, Ported/polished exhaust manifolds, taylor plug wires, low temp thermostat and fan switch. WCF catback exhaust
She's done!
Old 01-31-2005, 06:50 AM
grgoyl86 grgoyl86 is offline
Give Bob at Kick Hill Farm a call (www.kickhill.com), number is on the website. Tell him what you want to do, and he'll fix you up with what you need. I know others who have done this, and were happy with the results.
Old 01-31-2005, 12:06 PM
FierceGT's Avatar
I'm also doing the swap, but mine is going to be a frame up swap...I didn't realize how hard it was going to be untill I saw the harness was different. And trust me, those wires snake all around the car. They aren't easy to remove, so if your car currently runs and drives fine....you may be better off selling it and getting one that you like.
BTW, what's a water fall?
Old 01-31-2005, 08:13 PM
fierangero's Avatar
heres an email i got:
Along with dropping the engine/trans/cradle (which you are doing), the following will have to be changed or added.
Pedal assembly, steering column, shifter console, shifter, shifting cables, clutch hydraulic line, clutch master cyl, clutch slave cyl (to match trans used), flywheel (neutral balance on the 3.4), clutch assembly (to match trans used), manual engine wiring harness, repin 1 wire in C-500, modify cabin wiring for clutch pedal neutral safety switch and cruise kick off switch, pair of axles, water crossover pipe, and finally the transaxle with all brackets. The auto ECM can run the engine, but for emissions it may take one for a manual.
Hope this helps.
Ed Parks from The Fiero Factory
8710B Hwy 53 Toney, Ala 35773
She's done!
Old 02-01-2005, 10:23 PM
woowww way to much work, I think I'll go see another guy about his gt that I think is manual. (its been sitting in the same spot for years, poor car )
Old 02-09-2005, 08:19 PM
coop8267's Avatar
coop8267 coop8267 is offline
get the getrag 5
Old 02-23-2005, 08:56 AM
goatnipples2002 goatnipples2002 is offline
For all the money and work just go buy an engineless 4/5 speed and swap engine into it.
Turbo 351w E85
Old 02-23-2005, 10:37 AM
fierangero's Avatar
kick hill sells most of the stuff to swap it, just need a transaxle itself.
She's done!
