Go Back   Automotive Forums Car Chat > Jeep > General Discussion
Old 01-30-2005, 02:45 PM
beatruit beatruit is offline
Question starter or flywheel
starter seems to slip when cranking it was slipping occasionally and now slips and will only start by popping clutch
Old 01-30-2005, 02:59 PM
JDPascal JDPascal is offline
Re: starter or flywheel
By"popping clutch" do you mean letting the jeep roll fwd and letting the clutch out to turn the engine over??? or pushing the clutch in and letting it out to keep the starter engaged with the flywheel??
If the first is what you mean, I would suspect the starter drive is worn out and/or the teeth on the ring gear are flat where the starter tends to engage most often.
Replace the starter drive and while you have the starter off, roll the engine over to inspect the teeth on the flywheel.
JD
