Old 01-30-2005, 01:14 PM
jerseycavyz24 jerseycavyz24 is offline
audio/Battery Question?
Ok so i just bought a new Optima red top battery for my car. MY question is if i go to a car show n i shut my car off n turn on my tv's,audio,dvd player, n let it run for couple of hours more then likely my battery will die? whats the best way to get around this? add an another battery?
www.handsdownnj.com
Old 01-30-2005, 06:06 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
you will need a dedicated stereo battery and a starter battery that are seperated electrically by an isolator of dome type
Old 01-30-2005, 11:11 PM
GSteg's Avatar
GSteg GSteg is offline
Send a message via AIM to GSteg
Re: audio/Battery Question?
an optima red top is not a fix-it battery. It has its limitation and you cannot tell how long the battery will last without knowing how much current it's using. EVen so, you cannot tell because there are lots of variables that are in affect.
I love them sub wufers
Old 01-31-2005, 12:04 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
just let your car run or get a HELLA lot more batteries. lotta bad things can happed like amps frying from low current (some amps will some are fine) alternator over working itself trying to recharge a weak system and killing the battery from fully cycling it too many times.
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
